[PROJ] ct2 format to GTG
Even Rouault even.rouault at spatialys.com
Mon May 4 03:42:42 PDT 2020
Dalia,
> For Proj7 all grids must be transformed to GTG format.
You can still use the old formats, but this is considered as legacy.
> We have two grids in
> .ct2 format But I can not find a script in PROJ-data/grid_tools  for ct2 to
> GTG transformation. Could you give some suggestions on this ?
There's no ready-made script for that as .ct2 use is (thought to be) not widespread.
If it is just a single .ct2 file with a longitude and latitude offset, then,
- you can use "gdal_translate your.ct2 your.vrt -of VRT"
- edit the VRT to add all required and recommended metadata items as per the GTG spec
(attached an example of a VRT file corresponding to a combination of a .ct2 + .gtx to give you
an idea on how to insert metadata)
- convert the VRT to TIFF with:
	gdal_translate your.vrt your.tif -co COMPRESS=DEFLATE
		-co BLOCKYSIZE=YYY -co INTERLEAVE=BAND
  where YYY is the height of the grid if YYY <= 512
  Otherwise replace -co BLOCKYSIZE=YYY with -co TILED=YES
- run the check_gtiff_grid.py script to validate everything is right
If the .ct2 file is combined with a .gtx file to have for example a velocity grid, like
is_lmi_ISN_vel_beta.tif, then you can apply pretty much the above method by converting first
the .ct2 to VRT, and manually edit it to combine the .gtx band.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200504/c50ea9ff/attachment-0001.html>
<VRTDataset rasterXSize="223" rasterYSize="241">
  <SRS dataAxisToSRSAxisMapping="2,1">GEOGCRS["Unknown based on GRS80",
    DATUM["Unknown based on GRS80",
        ELLIPSOID["GRS 1980",6378137,298.257222101,
            LENGTHUNIT["metre",1]]],
    PRIMEM["Greenwich",0,
        ANGLEUNIT["degree",0.0174532925199433]],
    CS[ellipsoidal,2],
        AXIS["geodetic latitude (Lat)",north,
            ORDER[1],
        AXIS["geodetic longitude (Lon)",east,
            ORDER[2],
            ANGLEUNIT["degree",0.0174532925199433]]]
</SRS>
  <GeoTransform>  2.9166666666666670e+00,  1.6666666666666666e-01,  0.0000000000000000e+00,  7.3041666666666686e+01,  0.0000000000000000e+00, -8.3333333333333329e-02</GeoTransform>
  <Metadata>
    <MDI key="DESCRIPTION"></MDI>
    <MDI key="area_of_use">Nordic and Baltic countries</MDI>
    <MDI key="AREA_OR_POINT">Point</MDI>
    <MDI key="TIFFTAG_COPYRIGHT">The Nordic Geodetic Commission. Creative Commons Attribution 4.0 https://creativecommons.org/licenses/by/4.0/</MDI>
    <MDI key="TIFFTAG_DATETIME">2019:12:30 00:00:00</MDI>
    <MDI key="TIFFTAG_IMAGEDESCRIPTION">Deformation model covering the Nordic and Baltic countries. Used in transformations between global reference frames and the local realisations of ETRS89 in the Nordic and Baltic countries</MDI>
    <MDI key="TYPE">VELOCITY</MDI>
  </Metadata>
  <VRTRasterBand dataType="Float32" band="1">
    <Description>east_velocity</Description>
    <UnitType>millimetres per year</UnitType>
    <SimpleSource>
      <SourceFilename relativeToVRT="0">/home/even/proj/proj-datumgrid/europe/nkgrf03vel_realigned_xy.ct2</SourceFilename>
      <SourceBand>2</SourceBand> <!-- GDAL exposes the first physical component of the file (longitude offset normally, here east velocity) as the second band -->
      <SrcRect xOff="0" yOff="0" xSize="223" ySize="241" />
      <DstRect xOff="0" yOff="0" xSize="223" ySize="241" />
    </SimpleSource>
  </VRTRasterBand>
  <VRTRasterBand dataType="Float32" band="2">
    <Description>north_velocity</Description>
    <SimpleSource>
      <SourceBand>1</SourceBand> <!-- and the second physical component (latitude offset normally, here north velocity) as the first band -->
    </SimpleSource>
  </VRTRasterBand>
  <VRTRasterBand dataType="Float32" band="3">
    <Description>up_velocity</Description>
    <SimpleSource>
      <SourceFilename relativeToVRT="0">/home/even/proj/proj-datumgrid/europe/nkgrf03vel_realigned_z.gtx</SourceFilename>
    </SimpleSource>
  </VRTRasterBand>
</VRTDataset>
More information about the PROJ mailing list
