[PROJ] PROJ 7.2.0 & PROJ-data 1.3
Kristian Evers kristianevers at gmail.com
Sun Nov 1 01:56:41 PST 2020
All,
On behalf of the PROJ development team I am happy to announce the release
of PROJ 7.2.0 and PROJ-data 1.3.
The PROJ release includes a number of improvements, new features and bug
fixes. See the detailed release notes below. The PROJ-data package includes adds
new resources for Finish TIN shift transformations as well as the Japanese
GSIGEO2011 geoid.
Get the packages here:
http://download.osgeo.org/proj/proj-7.2.0.tar.gz
http://download.osgeo.org/proj/proj-7.2.0.zip
http://download.osgeo.org/proj/proj-data-1.3.tar.gz
http://download.osgeo.org/proj/proj-data-1.3.zip
/Kristian
7.2.0 Release Notes
 Updates
 + Command line tools:
   o Add multi-line PROJ string export capability, and use it by default in
     projinfo (unless --single-line is specified) (#2381)
 + Coordinate operations:
    o +proj=col_urban projection, implementing a EPSG projection method
      used by a number of projected CRS in Colombia (#2395)
    o +proj=tinshift for triangulation-based transformations (#2344)
    o Added ellipsoidal formulation of +proj=ortho (#2361)
 + Database
   o Update to EPSG 10.003 and make code base robust to dealing with
     WKT CRS with DatumEnsemble (#2370)
   o Added Finland tinshift operations (#2392)
   o Added transformation from JGD2011 Geographic 3D to JGD2011
     height using GSIGEO2011 (#2393)
   o Improve CompoundCRS identification and name morphing in VerticalCRS
     with ESRI WKT1 (#2386)
   o Added OGC:CRS27 and OGC:CRS83 CRS entries for NAD27 and NAD83
     in longitude, latitude order (#2350)
 + API
 o Added temporal, engineering, and parametric datum
   PJ_TYPE enumerations (#2274)
  o Various improvements to context handling (#2329, #2331)
  o proj_create_vertical_crs_ex(): add a ACCURACY option to provide
     an explicit accuracy, or derive it from the grid name if it is
     known (#2342)
   o proj_crs_create_bound_crs_to_WGS84(): make it work on
     verticalCRS/compoundCRS such as EPSG:4326+5773 and
     EPSG:4326+3855 (#2365)
   o promoteTo3D(): add a remark with the original CRS identifier (#2369)
   o Added proj_context_clone (#2383)
 Bug fixes
 o Avoid core dumps when copying contexts in certain scenarios (#2324)
 o proj_trans(): reset errno before attemptying a retry with a new
   coordinate operation (#2353)
 o PROJJSON schema corrected to allow prime meridians values with
   explicitly stating a unit (degrees assumed) (#2354)
 o Adjust createBoundCRSToWGS84IfPossible() and operation filtering
   (for POSGAR 2007 to WGS84 issues) (#2357)
 o createOperations(): several fixes affecting NAD83 -> NAD83(2011) (#2364)
 o WKT2:2019 import/export: handle DATUM (at top level object) with PRIMEM
 o WKT1_ESRI: fix import and export of CompoundCRS (#2389)
More information about the PROJ mailing list
