[PROJ] Combining custom transformations with EPSG
    Even Rouault
    even.rouault at spatialys.com
    Tue Nov  3 13:10:46 PST 2020
> > - ETRF2000_TO_NKG_ETRF00 using a fixed central epoch would need to be
> > another kind of operation. It would be a bit like the time-specific
> > Helmert transformation that is used in a few EPSG transformations (but we
> > currently don't map to a PROJ transformation).
> I am not sure I follow, are you thinking about a WKT2-mapping of
> +proj=deformation? Or perhaps an EPSG-mapping? At some point I will get
> round to submitting these transformations to the EPSG registry.
Yes I was talking about EPSG mapping ( WKT itself doesn't define any name of
operation method )
> Another solution is to not use NKG_ETRF00
> as a hub at all and simply make one big concatenated operation from ITRF2000
> to each national realization of ETRS89.
Yes, you would to the 1-hop handled case.
http://www.spatialys.com
More information about the PROJ
