[PROJ] [central_bureau at iers.org] IERS Message No. 411: The ISO Geodetic Registry
Javier Jimenez Shaw j1 at jimenezshaw.com
Fri Nov 20 06:50:45 PST 2020
I can't help thinking on XKCD Standards strip: https://xkcd.com/927/
.___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
On Fri, 20 Nov 2020 at 15:40, Greg Troxel <gdt at lexort.com> wrote:
> This was news to me and seems interesting and relevant.
> ---------- Forwarded message ----------
> From: central_bureau at iers.org
> To: messages at iers.org
> Cc:
> Bcc:
> Date: Fri, 20 Nov 2020 12:52:05 +0100 (CET)
> Subject: IERS Message No. 411: The ISO Geodetic Registry
> IERS Message No. 411                                   November 20, 2020
> The ISO Geodetic Registry is a structured database of international
> coordinate reference systems and transformations that is accessible
> through an on-line registry system at
> https://geodetic.isotc211.org
> The main purpose of the Registry is to serve as the primary source for
> authoritative information on reference systems and transformations that
> can be used not only by end users but also other registries, including
> the ubiquitous EPSG registry. Unlike many other registries, the
> information contained the ISO Geodetic Registry has been either directly
> entered or approved by the agencies responsible for defining and
> maintaining the reference systems and transformations. The ISO Geodetic
> Registry is not meant to compete with or replace other registries but,
> rather, to complement them as an authoritative source for their content.
> The ISO Geodetic Registry also supports the implementation of the Global
> Geodetic Reference Frame (GGRF) under the auspices of the UN GGIM
> Sub-Committee on Geodesy. The GGRF Implementation Plan has recommended
> the use of the ISO Geodetic Registry as the authoritative source of
> information on geodetic reference systems and transformations in order
> to foster the interoperability of geodetic data and products among UN
> Member States.
> This Registry is provided under the auspices of the ISO Technical
> Committee on geographic information/geomatics (ISO TC-211) and conforms
> to the ISO standards on spatial referencing by coordinates (ISO
> 19111:2007) and geodetic registries (ISO 19127:2019, ISO 19135-1:2015,
> ISP 19135-2:2012). In the near term, it is planned to bring the
> Registry's data model into conformance with the new ISO 19111:2019
> standard in order to properly represent modern reference systems such as
> dynamic reference frames and geoid-based vertical datums. A number of
> additional enhancements will improve the user interface. Information
> about these ISO standards can be found at https://www.iso.org.
> As specified in ISO 19135-1 and ISO 19127, a Control Body composed of
> geodetic experts nominated by the members of ISO/TC 211 is responsible
> for approving the content of the ISO Geodetic Registry together with the
> authoritative sources of the information. The Control Body is chaired by
> representatives appointed by the International Association of Geodesy,
> presently Michael Craymer as Chair and Larry Hothem as Vice-Chair.
> The contents of the Registry may be freely browsed by the general
> public. Comments on the Registry and its contents can also be submitted
> using the Registry's feedback link at the top of every Registry web
> page. Authorities wishing to submit their own reference systems and
> transformations can register for an account to do so. The Registry also
> provides a web service interface, allowing geospatial software to query
> and retrieve information from the Registry's database.
> For further information on the ISO Geodetic Registry, please visit the
> Registry website.
> Michael Craymer
> Chair, Control Body for the ISO Geodetic Registry
> on behalf of the Control Body
> IERS Messages are edited and distributed by the IERS Central Bureau.
> If not stated otherwise, the IERS is only the distributor of the message
> and is not responsible for its content.
> To submit texts for distribution, please write to
> <central_bureau at iers.org>.
> To subscribe or unsubscribe, please create an IERS account or modify it:
> https://www.iers.org/Login/Login/EN/login_node.html
> or write to <central_bureau at iers.org>.
> Archives: http://www.iers.org/Messages
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20201120/5f48d41b/attachment.html>
More information about the PROJ mailing list
