[PROJ] Using latest realization of a datum ensemble ?
Even Rouault even.rouault at spatialys.com
Wed Oct 14 12:04:25 PDT 2020
(Resending the last part of my message from Monday whose text-only output got
truncated for some reason. The HTML version was OK)
REAL SUBJECT
What is tricky in the suggestion to 'promote' to the latest realization of a
datum ensemble is that you might have both low accuracy transformations that >
exist like shown above for NAD83 -> WGS84 and high accuracy for NAD83(2011) ->
WGS84 (G1762) (here I assume that NAD83 would be an enssemble, which it is not
formally currently). Depending on the situation, one or the other might be
relevant.
So there could be 2 options:
1) in addition to the lower resolution results, also consider the ones using
the latest realization of the datum. and do that systematically
- Pro: more possibilities returned
- Con: more possibilities returned! (users might already be overwhelmed by
current output which in some cases can offer of the order of 100
possibilities), and greater pipeline computation time (there are already
optimizations/heuristics to avoid doing the advanced pipeline searchs, like
using an intermediate CRS/datum, when direct ones are returned.)
- Pro or con: the default pipeline (that is the one used by cs2cs or
proj_create_crs_to_crs() when the user has no say on the pipeline to use)
would probably be in a lot of situation the high resolution one, which might
be appropriate or not. The high accuracy pipelines also often need a
coordinate epoch, so when it is not specified in the input coordinates
provided to PROJ, the transformation will be done at the central epoch of the
Helmert transformation.
In some circumstances, I imagine there might not be a transformation
registered from/to the latest realization of a datum ensemble, but to an
earlier realization.
2) or the same, but do that only on user request (projinfo switch, new
function in C/C++ API).
- End users have to turn that on to benefit from the new capability
- Downstream software (like QGIS) has to make use of that new API, and
possibly reflect that in its user interface.
I am a bit unconfortable about having PROJ being "too smart" by default with
option 1. There are already known circumstances where it is too smart in a bad
sense, such as in one of the above examples with WGS 84 to ITRF2014, using a
NAD27 intermediate, or in https://github.com/OSGeo/PROJ/issues/2348
http://www.spatialys.com
More information about the PROJ mailing list
