[PROJ] Using latest realization of a datum ensemble ?
Greg Troxel gdt at lexort.com
Wed Oct 14 12:40:05 PDT 2020
Even Rouault <even.rouault at spatialys.com> writes:
1> (Resending the last part of my message from Monday whose text-only output got
> truncated for some reason. The HTML version was OK)
Thanks.  I don't see HTML so I missed this.
> REAL SUBJECT
> What is tricky in the suggestion to 'promote' to the latest realization of a
> datum ensemble is that you might have both low accuracy transformations that >
> exist like shown above for NAD83 -> WGS84 and high accuracy for NAD83(2011) ->
> WGS84 (G1762) (here I assume that NAD83 would be an enssemble, which it is not
> formally currently). Depending on the situation, one or the other might be
> relevant.
> So there could be 2 options:
> 1) in addition to the lower resolution results, also consider the ones using
> the latest realization of the datum. and do that systematically
> - Pro: more possibilities returned
> - Con: more possibilities returned! (users might already be overwhelmed by
> current output which in some cases can offer of the order of 100
> possibilities), and greater pipeline computation time (there are already
> optimizations/heuristics to avoid doing the advanced pipeline searchs, like
> using an intermediate CRS/datum, when direct ones are returned.)
> - Pro or con: the default pipeline (that is the one used by cs2cs or
> proj_create_crs_to_crs() when the user has no say on the pipeline to use)
> would probably be in a lot of situation the high resolution one, which might
> be appropriate or not. The high accuracy pipelines also often need a
> coordinate epoch, so when it is not specified in the input coordinates
> provided to PROJ, the transformation will be done at the central epoch of the
> Helmert transformation.
> In some circumstances, I imagine there might not be a transformation
> registered from/to the latest realization of a datum ensemble, but to an
> earlier realization.
I can see how this would get hard.
> 2) or the same, but do that only on user request (projinfo switch, new
> function in C/C++ API).
> - End users have to turn that on to benefit from the new capability
> - Downstream software (like QGIS) has to make use of that new API, and
> possibly reflect that in its user interface.
I don't see this as really fixing the problem, which is that people are
getting what I consider to be bad transforms, when those people might
not understand.
> I am a bit unconfortable about having PROJ being "too smart" by default with
> option 1. There are already known circumstances where it is too smart in a bad
> sense, such as in one of the above examples with WGS 84 to ITRF2014, using a
> NAD27 intermediate, or in https://github.com/OSGeo/PROJ/issues/2348
I think your idea of having entries in the database to lead to the
transforms to most-recent-realization is a very promising appraoch, and
probably the right approach.
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20201014/c3e07cd7/attachment.sig>
More information about the PROJ mailing list
