[PROJ] How to transform the XYZ coordinate (ITRF) to Latitude/Longitude?
Even Rouault even.rouault at spatialys.com
Wed Sep 2 14:18:55 PDT 2020
Lei,
> I am new to the Proj.
> I want to transfrom the ITRF geocentric  coordinates to the
> Latitude/Longitude. I did not find the solution after reading the document
> in https://proj.org/operations/conversions/cart.html
> I just found this:
> echo 17.7562015132 45.3935192042 133.12 2017.8 | cct +proj=cart
> +ellps=GRS80
> But I need the inverse transfrom.
> I guess the Proj have such function.
Yes, see the -I switch : https://proj.org/apps/cct.html
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200902/ae85f125/attachment.html>
More information about the PROJ mailing list
