[PROJ] How to transform the XYZ coordinate (ITRF) to Latitude/Longitude?
leiyang at fio.org.cn leiyang at fio.org.cn
Wed Sep 2 17:40:47 PDT 2020
Hi, Even
Thanks for your help. It works fine.
Now I am not very clear about the `+proj=string` meaning.  Such as `+proj=cart`.
Could give me a hint where to find the help document about this?
I would like to learn more.
Thanks
Lei
Date: 2020-09-03 05:18
To: proj
CC: leiyang at fio.org.cn
Subject: Re: [PROJ] How to transform the XYZ coordinate (ITRF) to Latitude/Longitude?
Lei,
> I am new to the Proj.
> I want to transfrom the ITRF geocentric coordinates to the
> Latitude/Longitude. I did not find the solution after reading the document
> in https://proj.org/operations/conversions/cart.html
> I just found this:
> echo 17.7562015132 45.3935192042 133.12 2017.8 | cct +proj=cart
> +ellps=GRS80
> But I need the inverse transfrom.
> I guess the Proj have such function.
Yes, see the -I switch : https://proj.org/apps/cct.html
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200903/b5475e86/attachment.html>
More information about the PROJ mailing list
