[PROJ] BoundCRS with BBox
Olivier PENA OPena at isagri.fr
Wed Aug 18 04:38:29 PDT 2021
Hi
I'm looking for a way to set area of use for a BoundCRS I define with WKT like this one :
BOUNDCRS[
    SOURCECRS[
        PROJCRS["Monte Mario / Italy zone 2",
            BASEGEOGCRS["Monte Mario",
                DATUM["Monte Mario",
                    ELLIPSOID["International 1924",6378388,297,
                        LENGTHUNIT["metre",1]]],
                PRIMEM["Greenwich",0,
                    ANGLEUNIT["degree",0.0174532925199433]],
                ID["EPSG",4265]],
            CONVERSION["unnamed",
                METHOD["Transverse Mercator",
                    ID["EPSG",9807]],
                PARAMETER["Latitude of natural origin",0,
                    ANGLEUNIT["degree",0.0174532925199433],
                    ID["EPSG",8801]],
                PARAMETER["Longitude of natural origin",15,
                    ID["EPSG",8802]],
                PARAMETER["Scale factor at natural origin",0.9996,
                    SCALEUNIT["unity",1],
                    ID["EPSG",8805]],
                PARAMETER["False easting",2520000,
                    LENGTHUNIT["metre",1],
                    ID["EPSG",8806]],
                PARAMETER["False northing",0,
                    ID["EPSG",8807]]],
            CS[Cartesian,2],
                AXIS["x",east,
                    ORDER[1],
                    LENGTHUNIT["metre",1]],
                AXIS["y",north,
                    ORDER[2],
            ID["EPSG",3004]]],
    TARGETCRS[
        GEOGCRS["WGS 84",
            DATUM["World Geodetic System 1984",
                ELLIPSOID["WGS 84",6378137,298.257223563,
            CS[ellipsoidal,2],
                AXIS["latitude",north,
                    ORDER[1],
                AXIS["longitude",east,
                    ORDER[2],
            ID["EPSG",4326]]],
    ABRIDGEDTRANSFORMATION["Transformation from Monte Mario to WGS84",
        METHOD["Position Vector transformation (geog2D domain)",
            ID["EPSG",9606]],
        PARAMETER["X-axis translation",-50.2,
            ID["EPSG",8605]],
        PARAMETER["Y-axis translation",-50.4,
            ID["EPSG",8606]],
        PARAMETER["Z-axis translation",84.8,
            ID["EPSG",8607]],
        PARAMETER["X-axis rotation",-0.69,
            ID["EPSG",8608]],
        PARAMETER["Y-axis rotation",-2.012,
            ID["EPSG",8609]],
        PARAMETER["Z-axis rotation",0.459,
            ID["EPSG",8610]],
        PARAMETER["Scale difference",0.99997192,
            ID["EPSG",8611]]],
    USAGE[
        SCOPE["unknown"],
        AREA["Italy - Sicily onshore"],
        BBOX[36.59,12.36,38.35,15.71]]
I would be happy if proj_get_area_of_use() on the crs return the Sicily BBox.
I ran a debug session and it seems that USAGE node is not taken account in buildBoundCRS() in io.cpp. Same behavior in the json parser.
Is this normal behavior ?
Thanks
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20210818/21ec6c78/attachment.html>
More information about the PROJ mailing list
