[PROJ] BoundCRS with BBox
Even Rouault even.rouault at spatialys.com
Wed Aug 18 04:59:52 PDT 2021
Olivier,
hum, good finding. This is actually an oversight of the implementation.
The WKT2 grammar
(http://docs.opengeospatial.org/is/18-010r7/18-010r7.html#149) does
indeed allow usage/scope/extent/id/remark for a bound CRS but our C++
classes do not allow for that now. Could you file a ticket in
https://github.com/OSGeo/PROJ/issues/new about that ?
Even
Le 18/08/2021 à 13:38, Olivier PENA a écrit :
> Hi
> I’m looking for a way to set area of use for a BoundCRS I define with
> WKT like this one :
> BOUNDCRS[
>     SOURCECRS[
>         PROJCRS["Monte Mario / Italy zone 2",
> BASEGEOGCRS["Monte Mario",
> DATUM["Monte Mario",
> ELLIPSOID["International 1924",6378388,297,
>               LENGTHUNIT["metre",1]]],
> PRIMEM["Greenwich",0,
> ANGLEUNIT["degree",0.0174532925199433]],
> ID["EPSG",4265]],
> CONVERSION["unnamed",
> METHOD["Transverse Mercator",
> ID["EPSG",9807]],
> PARAMETER["Latitude of natural origin",0,
> ANGLEUNIT["degree",0.0174532925199433],
> ID["EPSG",8801]],
> PARAMETER["Longitude of natural origin",15,
> ID["EPSG",8802]],
> PARAMETER["Scale factor at natural origin",0.9996,
> SCALEUNIT["unity",1],
> ID["EPSG",8805]],
>    PARAMETER["False easting",2520000,
> LENGTHUNIT["metre",1],
> ID["EPSG",8806]],
> PARAMETER["False northing",0,
> ID["EPSG",8807]]],
>    CS[Cartesian,2],
> AXIS["x",east,
> ORDER[1],
> LENGTHUNIT["metre",1]],
> AXIS["y",north,
> ORDER[2],
> ID["EPSG",3004]]],
>     TARGETCRS[
>         GEOGCRS["WGS 84",
>             DATUM["World Geodetic System 1984",
> ELLIPSOID["WGS 84",6378137,298.257223563,
> CS[ellipsoidal,2],
> AXIS["latitude",north,
> ORDER[1],
> AXIS["longitude",east,
> ORDER[2],
> ID["EPSG",4326]]],
> ABRIDGEDTRANSFORMATION["Transformation from Monte Mario to WGS84",
>         METHOD["Position Vector transformation (geog2D domain)",
> ID["EPSG",9606]],
> PARAMETER["X-axis translation",-50.2,
> ID["EPSG",8605]],
> PARAMETER["Y-axis translation",-50.4,
> ID["EPSG",8606]],
> PARAMETER["Z-axis translation",84.8,
> ID["EPSG",8607]],
> PARAMETER["X-axis rotation",-0.69,
> ID["EPSG",8608]],
> PARAMETER["Y-axis rotation",-2.012,
> ID["EPSG",8609]],
> PARAMETER["Z-axis rotation",0.459,
> ID["EPSG",8610]],
>         PARAMETER["Scale difference",0.99997192,
> ID["EPSG",8611]]],
>     USAGE[
> SCOPE["unknown"],
>         AREA["Italy - Sicily onshore"],
> BBOX[36.59,12.36,38.35,15.71]]
> I would be happy if proj_get_area_of_use() on the crs return the
> Sicily BBox.
> I ran a debug session and it seems that USAGE node is not taken
> account in buildBoundCRS() in io.cpp. Same behavior in the json parser.
> Is this normal behavior ?
> Thanks
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20210818/3fccbdb1/attachment-0001.html>
More information about the PROJ mailing list
