[PROJ] How to do Helmert transformation with +exact option in QGIS?
Lesparre, Jochem Jochem.Lesparre at kadaster.nl
Thu Feb 11 02:52:10 PST 2021
Even wrote:
> In the mean time, I've implemented something that enables to embed an arbitrary PROJ string pipeline in a BoundCRS:
https://github.com/OSGeo/PROJ/pull/2521 Of course that will not be interoperable outside of PROJ.
Thanks! I will probably ask EPSG to include de exact Helmert as transformation method when I ask them to include the CRS with the large rotation angles. But it will probably take a long time before this is available in QGIS. The new feature you have implemented will probably be available sooner, so it is very useful for solving my problem (and for all kind of other future applications). In which PROJ version will this new feature become available?
It will take some extra time before that PROJ version will be available in QGIS, so I still need a workaround for the mean time. I created a hgridshift file (with just 4 points at medium height) and that works good enough as workaround for now (typical horizontal error of 2 cm with a maximum of 7 cm).
Regards, Jochem
Disclaimer:
De inhoud van dit bericht is uitsluitend bestemd voor geadresseerde.
Gebruik van de inhoud van dit bericht door anderen zonder toestemming van het Kadaster
is onrechtmatig. Mocht dit bericht ten onrechte bij u terecht komen, dan verzoeken wij u
dit direct te melden aan de verzender en het bericht te vernietigen.
Aan de inhoud van dit bericht kunnen geen rechten worden ontleend.
Disclaimer:
The content of this message is meant to be received by the addressee only.
Use of the content of this message by anyone other than the addressee without the consent
of the Kadaster is unlawful. If you have received this message, but are not the addressee,
please contact the sender immediately and destroy the message.
No rights can be derived from the content of this message.
More information about the PROJ mailing list
