[PROJ] Tie breakers used when ordering candidate operations
Lesparre, Jochem Jochem.Lesparre at kadaster.nl
Fri Feb 12 17:05:04 PST 2021
PS: How to get people aware that coordinates are time-depentent is an interesting other problem. As long as there is still little software that enables people to deal with time-depentent coordinates, recommending plate-fixed refrence frame is an easy temporary solution for some applications.
Disclaimer:
De inhoud van dit bericht is uitsluitend bestemd voor geadresseerde.
Gebruik van de inhoud van dit bericht door anderen zonder toestemming van het Kadaster
is onrechtmatig. Mocht dit bericht ten onrechte bij u terecht komen, dan verzoeken wij u
dit direct te melden aan de verzender en het bericht te vernietigen.
Aan de inhoud van dit bericht kunnen geen rechten worden ontleend.
Disclaimer:
The content of this message is meant to be received by the addressee only.
Use of the content of this message by anyone other than the addressee without the consent
of the Kadaster is unlawful. If you have received this message, but are not the addressee,
please contact the sender immediately and destroy the message.
No rights can be derived from the content of this message.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20210213/a1c40361/attachment.html>
More information about the PROJ mailing list
