[PROJ] Tie breakers used when ordering candidate operations
Brian Shaw brian.shaw at noaa.gov
Tue Feb 16 16:02:32 PST 2021
All
There have been many discussions here and at NGS about WGS84 and how it
should or should not be used.  While it is not published yet there is a
paper that is close to being published about WGS84 that is coauthored by
an NGS Geodesist Michael Dennis and Esri Geodesist Kevin Kelly.  It
discusses all of the versions of WGS84 and their relationships to ITRF
that NGA says are roughly equivalent.
One reason for recommending people use ITRF over WGS84 is that WGS84
only uses 16 tracking stations for the global solution where ITRF2014
used 884 GNSS sites, 124 VLBI sites, 96 SLR sites and 71 DORIS sites
(according to these slides
https://www.iau.org/static/science/scientific_bodies/divisions/a/2018/Altamimi.pdf).
When I was talking with our Chief Geodesist about WGS84 he summed it up
( to the best of my memory for 2-3 years ago ) that WGS84 should/can be
used for navigation but should not be used for positioning (unless you
have military receivers).  WGS84's 2-3 meters of uncertainty is fine
while you are moving in a vehicle but not for determining coordinates at
a specific location unless that uncertainty works for your needs.
Ill make sure to email the PROJ list when this is published.
Cheers
Brian
On 2/12/2021 2:03 AM, Lesparre, Jochem via PROJ wrote:
> Greg wrote:
>>   People talk about WGS84
> Everyone should stop doing that and avoid EPSG:4326 at all times. ITRS is the one official international system, recognised by the UN.
> Greg wrote:
>> ITRF2008 is pretty much the same thing as WGS84(G1762) ), and ITRF2014
> The major difference is that WGS84(G1762) is really messy at centimetre-level. It ignores the tracking station velocities during the year and uses an annual step-wise update (at a random date in January) of tracking station coordinates used to generate ephemeris broadcast message.
> https://earth-info.nga.mil/GandG/publications/NGA_STND_0036_1_0_0_WGS84/NGA.STND.0036_1.0.0_WGS84.pdf
> Greg wrote:
>> So, I think people who ask for transforms to WGS84 should be told "That doesn't really make sense any more; I will assume you mean WGS84(G1762) which is basically the same as ITRF2014" and then you should use those transforms instead.
> That is what I am doing all the time, except that I first ask them "Do you really want time-dependent international coordinates? Otherwise, I will assume you mean ETRF2000".
> Regards, Jochem
> Disclaimer:
> De inhoud van dit bericht is uitsluitend bestemd voor geadresseerde.
> Gebruik van de inhoud van dit bericht door anderen zonder toestemming van het Kadaster
> is onrechtmatig. Mocht dit bericht ten onrechte bij u terecht komen, dan verzoeken wij u
> dit direct te melden aan de verzender en het bericht te vernietigen.
> Aan de inhoud van dit bericht kunnen geen rechten worden ontleend.
> Disclaimer:
> The content of this message is meant to be received by the addressee only.
> Use of the content of this message by anyone other than the addressee without the consent
> of the Kadaster is unlawful. If you have received this message, but are not the addressee,
> please contact the sender immediately and destroy the message.
> No rights can be derived from the content of this message.
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
Brian Shaw
Rocky Mountain Regional Advisor (CO, MT, WY)
NOAA's National Geodetic Survey (NGS)
Cell Phone # 240-988-6363
More information about the PROJ mailing list
