[PROJ] About Argentinian geoid file
Even Rouault even.rouault at spatialys.com
Sun May 2 04:19:22 PDT 2021
Hi Javier,
funny a few months ago, I tweeted about that to get help from the
Argentinian community but that didn't lead to anywhere. And just a
couple days ago, I tried to reach someone who seemed to have been
related to Geoide-Ar16 but didn't hear back.
The clause "Se debe compartir de manera libre y gratuita." (" It must be
shared freely and for free." with free meaning costless here) is
problematic as open data licenses must allow for commercial use.
I'm afraid we'd need a contact within IGN Argentina that has sufficient
determination and influence internally so they can adopt a commonly used
open data license. Probably pointing that many other geodetic agencies
already do that could help.
Hint: if there are international instances/forums where national
agencies collaborate together, it would be good if someone from this
list that can speak in such forums could give an awareness talk about
the importance of using open data licensing :-)
Even
Le 02/05/2021 à 12:56, Javier Jimenez Shaw a écrit :
> Hi
> I found that Argentina had published a geoid file for their geoid
> model "GEOIDE-Ar16".
> https://www.ign.gob.ar/NuestrasActividades/Geodesia/Geoide-Ar16
> <https://www.ign.gob.ar/NuestrasActividades/Geodesia/Geoide-Ar16>
> In EPSG everything is already registered:
> - Vertical CRS: "SRVN16 height" EPSG:9255
> - Geographic CRS: "POSGAR 2007" EPSG:5340 (2D) , EPSG:5342 (3D)
> - Compound CRS: "POSGAR 2007 + SRVN16 height" EPSG:9521
> - Transformations:
>   "POSGAR 2007 to SRVN16 height (1)" EPSG:9256
>   "POSGAR 2007 to POSGAR 2007 + SRVN16 height (1)" EPSG:9621
> The "only missing piece" is the License:
> https://www.ign.gob.ar/NuestrasActividades/Geodesia/Geoide-Ar16/calculadora
> <https://www.ign.gob.ar/NuestrasActividades/Geodesia/Geoide-Ar16/calculadora>
> (click at the bottom in "Términos y Condiciones").
> Their summary is
> "- Debe reconocerse la autoría del Instituto Geográfico Nacional de la
> República Argentina.
> - Se debe compartir de manera libre y gratuita.
> - Se permite su uso comercial únicamente en el caso de obras derivadas
> en que la información sea utilizada como insumo para generar un nuevo
> producto.
> - El IGN no se responsabiliza por las consecuencias de la utilización
> de la información descargada."
> I have already asked them if they can publish it with an standard open
> license to include it in PROJ. They answered that they consider a good
> initiative to include it in PROJ, but unfortunately it has only their
> license from the IGN.
> "Nos parece muy buena la iniciativa de incluir GEOIDE-Ar16 dentro de
> la librería PROJ, pero lamentablemente por el momento el producto
> tiene asociado el licenciamiento genérico y propio del IGN, el cual
> puede consultar el texto completo de los términos y condiciones dentro
> de
> (debajo de todo)."
> What do we do now? I am not a lawyer.
> Cheers,
> Javier
> .___ ._ ..._ .. . ._. .___ .. __ . _. . __..  ... .... ._ .__
> Entre dos pensamientos racionales
> hay infinitos pensamientos irracionales.
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20210502/8a0582b2/attachment.html>
More information about the PROJ mailing list
