[PROJ] Constant vertical offset
Javier Jimenez Shaw j1 at jimenezshaw.com
Mon Nov 1 05:32:10 PDT 2021
Hi
I want to make a transformation (at the end an
operation::CoordinateOperation) that replaces the geoid model with a local
constant value.
In some cases there is public grid file for a geoid model, but I can get a
(constant) undulation value (let's say 42.9m) in a (small) area of work. I
would like to include this undulation value in the transformation.
How can I do that? is there any pipeline option for that? (I do not see a
way in https://proj.org/operations/transformations/vgridshift.html) Or a
way to directly create the CoordinateOperation?
Thanks
.___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20211101/8241a170/attachment.html>
More information about the PROJ mailing list
