[PROJ] Constant vertical offset
Even Rouault even.rouault at spatialys.com
Mon Nov 1 09:01:19 PDT 2021
Javier
Le 01/11/2021 à 13:32, Javier Jimenez Shaw a écrit :
> Hi
> I want to make a transformation (at the end an
> operation::CoordinateOperation) that replaces the geoid model with a
> local constant value.
> In some cases there is public grid file for a geoid model, but I can
> get a (constant) undulation value (let's say 42.9m) in a (small) area
> of work. I would like to include this undulation value in the
> transformation.
> How can I do that? is there any pipeline option for that? (I do not
> see a way in
> https://proj.org/operations/transformations/vgridshift.html
> <https://proj.org/operations/transformations/vgridshift.html>) Or a
> way to directly create the CoordinateOperation?
You can use the
https://proj.org/operations/transformations/geogoffset.html with the dh
parameter. This is for example used for transformation EPSG:15596
Even
> Thanks
> .___ ._ ..._ .. . ._. .___ .. __ . _. . __..  ... .... ._ .__
> Entre dos pensamientos racionales
> hay infinitos pensamientos irracionales.
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20211101/418bda49/attachment.html>
More information about the PROJ mailing list
