[PROJ] Change of datum not working
Mathieu Poulin mathieu.poulin at mvtgeosolutions.com
Fri Nov 26 09:03:18 PST 2021
When creating a transformation that requires a change of datum, it does not work. For instance, going from Geographic coordinates in WGS84 to UTM coordinates in NAD83CSRS. It does convert from geographic lat,lon to UTM projection easting,northing but the datum remains WGS84.
I am using Proj 8.2 (but I've also tried this with Proj 7.1 and 7.2) with C++. Here is the code with comments describing the values of the variables, the expected output of the code and the actual output of the code.
// ENTRY: x=-1614798.938 y=-3690228.026 z=4929942.509
GeographicLib::Geocentric::WGS84().Reverse(x, y, z, point.m_latitude, point.m_longitude, point.m_ellipsoidal_height);
// REVERSE: point.m_latitude=50.937434634728845 point.m_longitude=-113.63360224940385 point.m_m_ellipsoidal_height=1005.9387180001410
PJ_COORD coord = proj_coord(point.m_latitude, point.m_longitude, point.m_ellipsoidal_height, 0.0);
PJ* proj_from_WGS84_to_2956 = proj_create_crs_to_crs(0, "EPSG:4326", "EPSG:2956", 0);
PJ_XYZ proj_point_2 = proj_trans(proj_from_WGS84_to_2956, PJ_FWD, coord).xyz;
// EXPECTED RESULT: 314967.330, 5646169.740, 1006.379
// ACTUAL RESULT:   314967.085, 5646169.595, 1005.939
Am I doing something wrong? Am I missing something? If someone could help me out with this bit of code, it would be hugely appreciated.
Thanks,
 - Mathieu Poulin
[cid:b842d2e7-e23d-4c75-9eb0-6cdf834de5b1]
Mathieu Poulin
Développeur | Developer
Division arpentage et géomatique
Département Recherche et Développement
Siège social
15069, boulevard Henri-Bourassa
Québec (Québec) G1G 3Z5, Canada
Tel : 1+(418) 641-0344
Sans frais: 1+ (888) 576-7898
mvtgeosolutions.com<http://www.mvtgeosolutions.com/>
[cid:ab93d6d0-85d4-4ebe-8af2-044e71f94958]<https://www.facebook.com/mvtgeosolutions>    [cid:a54b447d-ac65-4951-8fcf-d10c737d0c3a] <https://www.linkedin.com/company/mvtgeosolutions>     [cid:cfbd29c9-c9c3-4973-afce-0be0062013bb] <https://www.youtube.com/channel/UCOFguYWgpbxOlKndKRqqRRQ> <https://www.youtube.com/channel/UCOFguYWgpbxOlKndKRqqRRQ>
ATTENTION NOTICE
Les informations contenues dans le présent message et dans toute pièce qui lui est jointe sont confidentielles et peuvent être protégées par le secret professionnel, industriel et/ou droits d'auteurs. Ces informations sont à l'usage exclusif de son ou de ses destinataires. Si vous avez reçu ce message par mégarde, veuillez communiquer avec l'expéditeur au +1 (888) 576-7898 poste 101, l'effacer de tout disque dur ou autre média sur lequel il peut être enregistré et ne pas en conserver de copie. Merci.
This E-mail message and any attachment thereto contain confidential information which may be privileged, industrial secrets or copyrighted and which is intended for the exclusive use of its addressee(s). If you have received this communication in error, please immediately notify us by telephone at +1 (888) 576-7898 poste 101, erase it from any hard disk or other medium on which it may have been saved and do not keep any copy thereof. Thank you.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20211126/8d89041f/attachment-0001.html>
Type: image/png
Desc: Outlook-31dfdvgz.png
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20211126/8d89041f/attachment-0004.png>
Type: image/png
Desc: Outlook-gxopdjhy.png
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20211126/8d89041f/attachment-0005.png>
Type: image/png
Desc: Outlook-aio4tfz2.png
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20211126/8d89041f/attachment-0006.png>
Type: image/png
Desc: Outlook-ccv4tpf3.png
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20211126/8d89041f/attachment-0007.png>
More information about the PROJ mailing list
