[PROJ] Constant vertical offset
Javier Jimenez Shaw j1 at jimenezshaw.com
Mon Nov 29 08:12:27 PST 2021
I was thinking on a WKT that defines the offset as part of the CRS
defintion, in a similar way the geoid grid file can be defined.
.___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
On Mon, 29 Nov 2021 at 17:05, Even Rouault <even.rouault at spatialys.com>
wrote:
> Javier,
> If you need a WKT2 with a coordinate operation, then you can simply wrap
> any PROJ string expressing a coordinate operation like the following:
> $ projinfo "+proj=geogoffset +dh=5" -o WKT2:2019 -q
> CONVERSION["PROJ-based coordinate operation",
>     METHOD["PROJ-based operation method: +proj=geogoffset +dh=5"]]
> Of course only interoperable in the PROJ universe.
> Otherwise using Transformation::createGeographic3DOffsets() /
> createGeographic2DWithHeightOffsets() could have been an option, but if
> your source and target CRS aren't geographic, PROJ will complain when
> getting the PROJ transformation string.
> Even
> Le 29/11/2021 à 16:53, Javier Jimenez Shaw a écrit :
> Thanks Even
> Is there anything equivalent to that as Vertical CRS to use in a Compound?
> I know it is not correct geodetically, but I want it just as a WKT
> temporary object. I just need that PROJ is able to understand it and use it
> in a transformation.
> That is, given a horizontal CRS, I want to create a compound (or anything
> equivalent) with a vertical offset (as WKT2 if it makes things easier)
> Thanks.
> On Mon, 1 Nov 2021 at 17:01, Even Rouault <even.rouault at spatialys.com>
> wrote:
>> Javier
>> Le 01/11/2021 à 13:32, Javier Jimenez Shaw a écrit :
>> Hi
>> I want to make a transformation (at the end an
>> operation::CoordinateOperation) that replaces the geoid model with a local
>> constant value.
>> In some cases there is public grid file for a geoid model, but I can get
>> a (constant) undulation value (let's say 42.9m) in a (small) area of work.
>> I would like to include this undulation value in the transformation.
>> How can I do that? is there any pipeline option for that? (I do not see a
>> way in https://proj.org/operations/transformations/vgridshift.html) Or a
>> way to directly create the CoordinateOperation?
>> You can use the
>> https://proj.org/operations/transformations/geogoffset.html with the dh
>> parameter. This is for example used for transformation EPSG:15596
>> Even
>> Thanks
>> PROJ mailing listPROJ at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/proj
>> -- http://www.spatialys.com
>> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20211129/4602a2e6/attachment-0001.html>
More information about the PROJ mailing list
