[PROJ] Constant vertical offset
Even Rouault even.rouault at spatialys.com
Mon Nov 29 08:04:57 PST 2021
Javier,
If you need a WKT2 with a coordinate operation, then you can simply wrap
any PROJ string expressing a coordinate operation like the following:
$ projinfo "+proj=geogoffset +dh=5" -o WKT2:2019 -q
CONVERSION["PROJ-based coordinate operation",
     METHOD["PROJ-based operation method: +proj=geogoffset +dh=5"]]
Of course only interoperable in the PROJ universe.
Otherwise using Transformation::createGeographic3DOffsets() /
createGeographic2DWithHeightOffsets() could have been an option, but if
your source and target CRS aren't geographic, PROJ will complain when
getting the PROJ transformation string.
Even
Le 29/11/2021 à 16:53, Javier Jimenez Shaw a écrit :
> Thanks Even
> Is there anything equivalent to that as Vertical CRS to use in a
> Compound? I know it is not correct geodetically, but I want it just as
> a WKT temporary object. I just need that PROJ is able to understand it
> and use it in a transformation.
> That is, given a horizontal CRS, I want to create a compound (or
> anything equivalent) with a vertical offset (as WKT2 if it makes
> things easier)
> Thanks.
> .___ ._ ..._ .. . ._. .___ .. __ . _. . __..  ... .... ._ .__
> Entre dos pensamientos racionales
> hay infinitos pensamientos irracionales.
> On Mon, 1 Nov 2021 at 17:01, Even Rouault <even.rouault at spatialys.com
> <mailto:even.rouault at spatialys.com>> wrote:
>     Javier
>     Le 01/11/2021 à 13:32, Javier Jimenez Shaw a écrit :
>>     Hi
>>     I want to make a transformation (at the end an
>>     operation::CoordinateOperation) that replaces the geoid model
>>     with a local constant value.
>>     In some cases there is public grid file for a geoid model, but I
>>     can get a (constant) undulation value (let's say 42.9m) in a
>>     (small) area of work. I would like to include this undulation
>>     value in the transformation.
>>     How can I do that? is there any pipeline option for that? (I do
>>     not see a way in
>>     https://proj.org/operations/transformations/vgridshift.html
>>     <https://proj.org/operations/transformations/vgridshift.html>) Or
>>     a way to directly create the CoordinateOperation?
>     You can use the
>     https://proj.org/operations/transformations/geogoffset.html
>     <https://proj.org/operations/transformations/geogoffset.html> with
>     the dh parameter. This is for example used for transformation
>     EPSG:15596
>     Even
>>     Thanks
>>     _______________________________________________
>>     PROJ mailing list
>>     PROJ at lists.osgeo.org  <mailto:PROJ at lists.osgeo.org>
>>     https://lists.osgeo.org/mailman/listinfo/proj  <https://lists.osgeo.org/mailman/listinfo/proj>
>     http://www.spatialys.com  <http://www.spatialys.com>
>     My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20211129/a58a9b9b/attachment.html>
More information about the PROJ mailing list
