[PROJ] Strange axes in LV03
Even Rouault even.rouault at spatialys.com
Fri Oct 8 04:02:29 PDT 2021
I don't think that's a mistake. The choice of abbreviations is indeed
somewhat random, or might depend on local usages. Using the direction
will be more robust.
Le 08/10/2021 à 12:29, Javier Jimenez Shaw a écrit :
> Hi
> Reading the axes of EPSG:21781
> https://epsg.org/crs_21781/CH1903-LV03.html
> <https://epsg.org/crs_21781/CH1903-LV03.html> (Switzerland) I found
> something strange:
>     CS[Cartesian,2],
>         AXIS["easting (Y)",east,
>             ORDER[1],
>             LENGTHUNIT["metre",1]],
>         AXIS["northing (X)",north,
>             ORDER[2],
> The first axis is east... however the abbreviation is "Y". Is there
> any reason for that? Is it just a mistake in EPSG data? I have the
> impression that I should ignore that abbreviation, and relay only on
> the direction. But it is getting hard ;)
> Thanks.
> .___ ._ ..._ .. . ._. .___ .. __ . _. . __..  ... .... ._ .__
> Entre dos pensamientos racionales
> hay infinitos pensamientos irracionales.
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20211008/a3fb00f1/attachment.html>
More information about the PROJ mailing list
