[PROJ] CRS explorer
Javier Jimenez Shaw j1 at jimenezshaw.com
Thu Oct 14 05:01:55 PDT 2021
Thanks Jochem and Thomas
On Thu, 14 Oct 2021 at 13:18, Lesparre, Jochem <Jochem.Lesparre at kadaster.nl>
wrote:
> Javier,
> Thanks! It is much faster than the epsg.org map search and it provides
> codes of other authorities too. That will save me a lot of time. Personally
> I would prefer the links to epsg.org to point to the human readable
> browse report instead of the WKT string to save me the additional mouse
> click.
That would be the great. Unfortunately I do not know how to construct that
link. The link to the WKT has just the code number. I could try to figure
out the rule to convert the CRS name to that URL.
> However, the thing I’m missing most in epsg.org is the possibility to
> find the transformation codes associated with a specific CRS code easily.
> Do you have ideas on how that could be made easier too?
 What I did was pre-produce a json using pyproj.database.query_crs_info,
that later is read by the webpage. If I understand correctly what you
suggest, that would need another query to the database, that is not
currently available in pyproj.
> Regards, Jochem
> Disclaimer:
> De inhoud van deze e-mail is vertrouwelijk en uitsluitend bestemd voor de
> geadresseerde(n).
> Gebruik, openbaarmaking, vermenigvuldiging, verspreiding en/of
> verstrekking van deze informatie aan derden is niet toegestaan.
> Op al onze producten en diensten zijn onze algemene leveringsvoorwaarden
> van toepassing
> [https://www.kadaster.nl/algemene-leveringsvoorwaarden].
> Disclaimer:
> This email and any files transmitted with it are confidential and intended
> solely for the use of the individual or entity to whom they are addressed.
> If you are not the intended recipient, you are notified that disclosing,
> copying, distributing or taking any action in reliance on the contents of
> this information is strictly prohibited.
> Our general terms and conditions of delivery apply to all our products and
> services
> [https://www.kadaster.com/general-terms-and-conditions].
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20211014/9e61e99d/attachment-0001.html>
More information about the PROJ mailing list
