[PROJ] CRS explorer
Javier Jimenez Shaw j1 at jimenezshaw.com
Thu Oct 14 13:00:35 PDT 2021
Jochem,
I think I found the pattern for the EPSG url (not difficult), and changed
the link. If you find any link that does not work, please, let me know.
.___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
On Thu, 14 Oct 2021 at 14:01, Javier Jimenez Shaw <j1 at jimenezshaw.com>
wrote:
> Thanks Jochem and Thomas
> On Thu, 14 Oct 2021 at 13:18, Lesparre, Jochem <
> Jochem.Lesparre at kadaster.nl> wrote:
>> Javier,
>> Thanks! It is much faster than the epsg.org map search and it provides
>> codes of other authorities too. That will save me a lot of time. Personally
>> I would prefer the links to epsg.org to point to the human readable
>> browse report instead of the WKT string to save me the additional mouse
>> click.
> That would be the great. Unfortunately I do not know how to construct that
> link. The link to the WKT has just the code number. I could try to figure
> out the rule to convert the CRS name to that URL.
>> However, the thing I’m missing most in epsg.org is the possibility to
>> find the transformation codes associated with a specific CRS code easily.
>> Do you have ideas on how that could be made easier too?
>  What I did was pre-produce a json using pyproj.database.query_crs_info,
> that later is read by the webpage. If I understand correctly what you
> suggest, that would need another query to the database, that is not
> currently available in pyproj.
>> Regards, Jochem
>> Disclaimer:
>> De inhoud van deze e-mail is vertrouwelijk en uitsluitend bestemd voor de
>> geadresseerde(n).
>> Gebruik, openbaarmaking, vermenigvuldiging, verspreiding en/of
>> verstrekking van deze informatie aan derden is niet toegestaan.
>> Op al onze producten en diensten zijn onze algemene leveringsvoorwaarden
>> van toepassing
>> [https://www.kadaster.nl/algemene-leveringsvoorwaarden].
>> Disclaimer:
>> This email and any files transmitted with it are confidential and
>> intended solely for the use of the individual or entity to whom they are
>> addressed.
>> If you are not the intended recipient, you are notified that disclosing,
>> copying, distributing or taking any action in reliance on the contents of
>> this information is strictly prohibited.
>> Our general terms and conditions of delivery apply to all our products
>> and services
>> [https://www.kadaster.com/general-terms-and-conditions].
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20211014/89e07b8f/attachment.html>
More information about the PROJ mailing list
