[PROJ] CRS explorer
Paul Harwood runette at gmail.com
Sat Oct 16 01:11:29 PDT 2021
This is really useful - thanks :)
On Thu, 14 Oct 2021 at 23:01, Javier Jimenez Shaw <j1 at jimenezshaw.com>
wrote:
> Jochem,
> I think I found the pattern for the EPSG url (not difficult), and changed
> the link. If you find any link that does not work, please, let me know.
> .___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
> Entre dos pensamientos racionales
> hay infinitos pensamientos irracionales.
> On Thu, 14 Oct 2021 at 14:01, Javier Jimenez Shaw <j1 at jimenezshaw.com>
> wrote:
>> Thanks Jochem and Thomas
>> On Thu, 14 Oct 2021 at 13:18, Lesparre, Jochem <
>> Jochem.Lesparre at kadaster.nl> wrote:
>>> Javier,
>>> Thanks! It is much faster than the epsg.org map search and it provides
>>> codes of other authorities too. That will save me a lot of time. Personally
>>> I would prefer the links to epsg.org to point to the human readable
>>> browse report instead of the WKT string to save me the additional mouse
>>> click.
>> That would be the great. Unfortunately I do not know how to construct
>> that link. The link to the WKT has just the code number. I could try to
>> figure out the rule to convert the CRS name to that URL.
>>> However, the thing I’m missing most in epsg.org is the possibility to
>>> find the transformation codes associated with a specific CRS code easily.
>>> Do you have ideas on how that could be made easier too?
>>  What I did was pre-produce a json using pyproj.database.query_crs_info,
>> that later is read by the webpage. If I understand correctly what you
>> suggest, that would need another query to the database, that is not
>> currently available in pyproj.
>>> Regards, Jochem
>>> Disclaimer:
>>> De inhoud van deze e-mail is vertrouwelijk en uitsluitend bestemd voor
>>> de geadresseerde(n).
>>> Gebruik, openbaarmaking, vermenigvuldiging, verspreiding en/of
>>> verstrekking van deze informatie aan derden is niet toegestaan.
>>> Op al onze producten en diensten zijn onze algemene leveringsvoorwaarden
>>> van toepassing
>>> [https://www.kadaster.nl/algemene-leveringsvoorwaarden].
>>> Disclaimer:
>>> This email and any files transmitted with it are confidential and
>>> intended solely for the use of the individual or entity to whom they are
>>> addressed.
>>> If you are not the intended recipient, you are notified that disclosing,
>>> copying, distributing or taking any action in reliance on the contents of
>>> this information is strictly prohibited.
>>> Our general terms and conditions of delivery apply to all our products
>>> and services
>>> [https://www.kadaster.com/general-terms-and-conditions].
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20211016/444537f4/attachment.html>
More information about the PROJ mailing list
