[PROJ] 2D Helmert transformation after the map projection and PROJ won't use added transformation from the database
Schupp, Leon LSchupp at moba.de
Thu Sep 9 02:34:25 PDT 2021
Hello everyone,
I got 2 Questions.
First question:
Is it possible to add a 2D Helmert transformation to the proj.db database. I tried adding it to the helmert_transformation_table, but proj.db didn't let me choose a projected crs as source transformation.
I want to add a helmert transformation which uses ETRS89/GK25 as source crs and transforms it into the finnish VVJ crs.
My second question is:
I tried adding the helmert transformation as a proj string to the other_transformation table, but proj won't use it. I also added an entry into the usage table for the transformation.
When I add a normal helmert transformation or a grid transformation, proj has no problem using them after they are added, but not when I add a transformation in other_transformation.
Thanks for your help.
Leon Schupp
Student - Development Engineer
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20210909/01fb8ae8/attachment.html>
More information about the PROJ mailing list
