[PROJ] 2D Helmert transformation after the map projection and PROJ won't use added transformation from the database
Even Rouault even.rouault at spatialys.com
Thu Sep 9 02:55:35 PDT 2021
Leon,
> First question:
> Is it possible to add a 2D Helmert transformation to the proj.db
> database. I tried adding it to the helmert_transformation_table, but
> proj.db didn’t let me choose a projected crs as source transformation.
Yes as designed currently it is limited to source and target CRS being
geographic CRS
> I want to add a helmert transformation which uses ETRS89/GK25 as
> source crs and transforms it into the finnish VVJ crs.
> My second question is:
> I tried adding the helmert transformation as a proj string to the
> other_transformation table, but proj won’t use it. I also added an
> entry into the usage table for the transformation.
> When I add a normal helmert transformation or a grid transformation,
> proj has no problem using them after they are added, but not when I
> add a transformation in other_transformation.
Show your SQL INSERT statements
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20210909/d5427a86/attachment.html>
More information about the PROJ mailing list
