[PROJ] Different transformation results between PROJ 9.0.0 and PROJ 9.0.1
Alexander Nehrbass alex.bass at mailbox.org
Fri Aug 5 02:56:42 PDT 2022
Thank you Greg and Even for you detailed answers.
It is clear now, where the difference comes from.
And great, that the bbox bug was fixed.
Alex
On 04.08.22 19:51, Even Rouault wrote:
> Alexander,
> in 9.0.0 the operation that gets applied is:
> unknown id, Inverse of WGS 84 to EGM96 height (1) + Inverse of NAD83
> to WGS 84 (43) + NAD83 to NAD83(HARN) (3) + NAD83(HARN) to NAVD88
> height (5) + Inverse of NAD83 to NAD83(HARN) (3) + SPCS83 California
> zone 1 (US Survey feet), 3.15 m, unknown domain of validity, at least
> one grid missing
> PROJ string:
> +proj=pipeline
>   +step +proj=axisswap +order=2,1
>   +step +proj=unitconvert +xy_in=deg +xy_out=rad
>   +step +proj=vgridshift +grids=us_nga_egm96_15.tif +multiplier=1
>   +step +inv +proj=vgridshift +grids=us_noaa_g1999u05.tif +multiplier=1
>   +step +inv +proj=hgridshift +grids=us_noaa_cnhpgn.tif
>   +step +proj=lcc +lat_0=39.3333333333333 +lon_0=-122
> +lat_1=41.6666666666667
>         +lat_2=40 +x_0=2000000.0001016 +y_0=500000.0001016 +ellps=GRS80
>   +step +proj=unitconvert +xy_in=m +xy_out=us-ft
> and in 9.0.1/master:
> NAD83(HARN) to WGS 84 (3) + NAD83(HARN) to NAVD88 height (5) + Inverse
> of NAD83 to NAD83(HARN) (3) + SPCS83 California zone 1 (US Survey
> feet), 2.1 m, unknown domain of validity, at least one grid missing
> PROJ string:
> +proj=pipeline
>   +step +proj=cart +ellps=WGS84
>   +step +inv +proj=helmert +x=-0.991 +y=1.9072 +z=0.5129
> +rx=-0.0257899075194932
>         +ry=-0.0096500989602704 +rz=-0.0116599432323421 +s=0
>         +convention=coordinate_frame
>   +step +inv +proj=cart +ellps=GRS80
> So the difference is that in 9.0.1/master NAD83(HARN) to WGS 84
> transformation is modeled by a Helmert transformation, whereas in 9.0
> its is a null transformation. This is likely due to a new record in
> the EPSG database incorporated in >= 9.0.1
> (I got this by looking at the pipeline name emitted by PROJ_DEBUG=2 on
> cs2cs, and then getting the list of transformations from projinfo)
> Regarding the differences between specifying or not --bbox, this was a
> bug for which I've queued a fix in
> https://github.com/OSGeo/PROJ/pull/3282. With that fix I get the same
> result when specifying --bbox -122.1,40.9,-121.9,41.1 or not
> Even
> Le 04/08/2022 à 11:34, Alexander Nehrbass via PROJ a écrit :
>> Hi everyone,
>> I’m observing a significant difference between PROJ 9.0.0 and PROJ
>> 9.0.1/master[c482ea8] when doing some coordinate transformations:
>> $ echo 41.0 -122.0 0.0 | PROJ_NETWORK=ON ./cs2cs EPSG:4326+5773
>> EPSG:2225+5703 -d 8
>> 6561666.44282083    2247576.19215388 0.21377754 (in PROJ 9.0.0)
>> 6561670.17486934    2247574.26932194 0.70338464 (PROJ 9.0.1/master)
>> When running these commands with PROJ_DEBUG=3, I can see that
>> different transformation pipelines are being used. PROJ 9.0.0 uses an
>> 11 step pipeline whereas PROJ 9.0.1 uses a 7 step pipeline.
>> While trying to understand where this difference might come from, I
>> started to play around with the –bbox option. Doing the above
>> transformation with a bounding box surprisingly does NOT lead to
>> different transformation results between PROJ 9.0.0 and PROJ
>> 9.0.1/master:
>> EPSG:2225+5703 -d 8 --bbox -122.1,40.9,-121.9,41.1
>> 6561666.44282083    2247576.19215388 0.31567764
>> As you can see the horizontal coordinates are the same as when doing
>> the transformation without the bounding box in PROJ 9.0.0, however
>> there is a difference in the vertical coordinate. I also tried
>> changing the size of the bounding box which didn’t seem to have an
>> influence.
>> My questions at the moment are:
>> 1. Where does the difference between PROJ 9.0.0 and 9.0.1 when doing
>> the transformation without the bounding box come from?
>> 2. How does using the bbox option affect the transformation results?
>> In particular:
>> 2a. Why are the differences between PROJ 9.0.0 and 9.0.1 gone when
>> using a bounding box?
>> 2b. Why does the vertical coordinate in PROJ 9.0.0 differ when doing
>> the transformation with and without the bounding box?
>> 3. Related bonus question: I was under the impression that passing
>> the -bbox option to projinfo would result in projinfo returning
>> exactly one transformation. However, this seems in correct. Was I
>> under the wrong impression? E.g.:
>> $ ./projinfo -s EPSG:4326+5773 -t EPSG:2225+5703 --spatial-test
>> intersects --bbox -122.1,40.9,-121.9,41.1
>> Any help with finding answers to these question is highly appreciated.
>> Thanks in advance and best regards,
>> Alex
>> PROJ mailing list
>> PROJ at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/proj
More information about the PROJ mailing list
