[PROJ] strange output in cs2cs
Javier Jimenez Shaw j1 at jimenezshaw.com
Wed Aug 17 08:56:18 PDT 2022
Hi
There is some strange behavior in "cs2cs"
I have a file.txt with this content
$ cat file.txt
641479.6040 973128.5014 144.6338
641534.7456 973199.8717 138.9833
642094.9325 973945.9479 168.1343
and running this command produces this strange result
$ cs2cs EPSG:6537 EPSG:6318 -d 8 file.txt
38.82056164 -76.22733569 0.00000000641479.6040 973128.5014 144.6338
41.50375380 -73.95449855 138.98330000
41.50579170 -73.95243612 168.13430000
(the proper coordinates are the last 2 lines)
Am I using cs2cs in a wrong way?
Thanks
.___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20220817/52415989/attachment.htm>
More information about the PROJ mailing list
