[PROJ] Proj9 small library size
Charles Karney charles.karney at gmail.com
Tue Aug 16 13:31:04 PDT 2022
I opened a issue to address this...
https://github.com/OSGeo/PROJ/issues/3286
On 8/16/22 16:08, Greg Troxel wrote:
> Sebastiaan Couwenberg <sebastic at xs4all.nl> writes:
>> On 8/16/22 14:03, Greg Troxel wrote:
>>> Even Rouault <even.rouault at spatialys.com> writes:
>>>> @Mike That's a different thing. libproj-dev from PROJ 7 includes the
>>>> static .a library, whereas the one from PROJ 9 doesn't (since PROJ
>>>> CMake builds only build shared or static libraries, but not both at
>>>> the same time)
> (Charles: thanks for the hint; maybe this can be patched in proj to get
> back to standard behavior so that the switch to cmake isn't a
> regression.)
More information about the PROJ mailing list
