[PROJ] Plate motion models
Steve Riddell sriddell at geocue.com
Fri Feb 11 13:27:26 PST 2022
It did not occur to me initially, but all I had to do was add +dx/dy/dz terms in the Helmert string for NOAM in the init file. It works perfectly.
Sent: Wednesday, February 9, 2022 3:43 PM
To: Even Rouault <even.rouault at spatialys.com>; proj at lists.osgeo.org
Cc: Kristian Evers <kreve at sdfe.dk>
Subject: RE: [PROJ] Plate motion models
Thank you again for the assistance. That was a huge help. It works as expected, based on the delivered ITRF2008/ITRF2014 init files.
Perhaps it should be noted that the delivered models support only 3-rotation parameters. The paper, “ITRF2008 plate motion model, Z. Altamimi, et al.”, and the HTDP documentation indicates that plates NOAM, PCFC, and CARB, include translation rates as well: (0.41,0.22,0.41)mm/yr.  The practical difference then is sub-centimeter, but noticeable when comparing with HTDP (over areas not covered by HTDP’s velocity grids).
Thanks again,
steve
From: Even Rouault <even.rouault at spatialys.com<mailto:even.rouault at spatialys.com>>
Sent: Monday, February 7, 2022 9:18 AM
To: Steve Riddell <sriddell at geocue.com<mailto:sriddell at geocue.com>>; proj at lists.osgeo.org<mailto:proj at lists.osgeo.org>
Subject: Re: [PROJ] Plate motion models
Hi Steve,
Assuming lon=-100 lat=40 z=0,  I believe (not sure! and in particular if that's geodetically meaningful to chain so many transformations) you should use a pipeline like the following one, which will do:
- conversion to cartesian coordinate space
- apply the ITRF2000 to ITRF2014 transformation preserving observation epoch of 2022.1
- apply the ITRF2014:NOAM model using a target epoch of 2010 (hence the +inv, as naturally the transformation would use +t_epoch as the "source") for a point at observation epoch of 2022.1
- force the observation epoch to 2010
- apply the ITRF2014 to ITRF2000 transformation (at epoch 2010)
- conversion to lat, lon coordinate space
echo -100 40 0 2022.1 | cct -d 8 +proj=pipeline \
    +step +proj=cart +ellps+GRS80 \
    +step +inv +init=ITRF2014:ITRF2000 \
    +step +inv +init=ITRF2014:NOAM +t_epoch=2010 \
    +step +proj=set +v_4=2010 \
    +step +init=ITRF2014:ITRF2000 \
    +step +inv +proj=cart +ellps+GRS80
I get:
-99.99999790     40.00000064    0.00755196     2010.0000
If using ITRF2008 instead of ITRF2014, I get:
  -99.99999854     40.00000065    0.00909276     2010.0000
I've also tried using a plate-fixed CRS as an intermediate using what is available in EPSG
First with NAD83(CORS96) since there's a direct transformation for it in EPSG (not quite "direct" since when looking at the comments, it already results from concatenation of ITRF96>97 and IERS ITRF97>2000 transformations)
(order is lat, lon here)
$ echo 40 -100 0 2022.1 | cs2cs -d 8 "ITRF2000" "NAD83(CORS96)" | cct -d 8 +proj=set +v_4=2010 | cs2cs -d 8 "NAD83(CORS96)"  "ITRF2000"
40.00000067    -99.99999766 -0.00447640     2010.0000
Or if using NAD83(2011) (there's a transformation between NAD83(2011) and ITRF2008 in EPSG (concatenation of ITRF96>97 and IERS ITRF97>2008 transformations), and PROJ will use the ITRF2008 to ITRF2000 transformation in addition
$ echo 40 -100 0 2022.1 | cs2cs -d 8 "ITRF2000" "NAD83(2011)" | cct -d 8 +proj=set +v_4=2010 | cs2cs -d 8 "NAD83(2011)"  "ITRF2000"
40.00000066    -99.99999765 -0.00447668     2010.0000
So results are somewhat consistent, at least in the lat, lon space (not for z values)
Best regards,
Even
Le 07/02/2022 à 14:49, Steve Riddell a écrit :
The data for the ITFR2008 & ITRF2014 plate motion models are delivered with PROJ as init files. From the documentation, 8.7, I think I see how an +init proj string can be used for changing epochs between ITFR frames (e.g. ITRF2000 to ITRF2005), but can someone please give an example of using the plate models? For example, if I have a point in ITRF2000 epoch 2022.1 and I want to use the NOAM plate model to move it to 2010.0, what would be the +init string? I’m assuming cct would be an appropriate application for processing this string?
Thanks for any assistance!
Steve
PROJ mailing list
PROJ at lists.osgeo.org<mailto:PROJ at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20220211/a38e3de9/attachment.html>
More information about the PROJ mailing list
