[PROJ] Plate motion models
Even Rouault even.rouault at spatialys.com
Fri Feb 11 14:33:22 PST 2022
Interesting... The "ITRF2008 plate motion model, Z. Altamimi, et al"
paper (https://agupubs.onlinelibrary.wiley.com/doi/10.1029/2011JB008930)
says:
- "The estimated ORB could be considered as not significant at the 95
per cent confidence level (i.e. two-sigma confidence level)." (and
indeed if you look the values at one sigma dy=0.22 ± 0.32 mm/year , the
significance seems questionable) and "we found a small origin rate bias,
at the level of 0.4 ± 0.6 mm/a (95 per cent confidence limits), which
could be considered as insignificant",
- but also "However, the users are advised to use the complete
ITRF2008-PMM parameters: the plate angular velocities (Table 3
<https://agupubs.onlinelibrary.wiley.com/doi/10.1029/2011JB008930#jgrb17142-tbl-0003>)
and the translation rate components (Table 2
<https://agupubs.onlinelibrary.wiley.com/doi/10.1029/2011JB008930#jgrb17142-tbl-0002>)."
@Kristian : do you think we should alter the existing ITRF2008 values or
add a ITRF2008_with_tr file that incorporates them (I guess from the
ITRF2008 paper that this would be for all plates, even if HTDP only
mentions that for the 3 plates of interest for the US), the later would
be advised for people wanting to reproduce HTDP values ?
(note: I don't pretend to understand the paper :-))
(note2: Table 2 of
https://geodesy.noaa.gov/TOOLS/Htdp/HTDP-user-guide.pdf has also a lot
of values for secondary and tertiary plates for ITRF2014 coming from
other sources than Z. Altamimi et al, 2017, ITRF2014 plate motion model
Le 11/02/2022 à 22:27, Steve Riddell a écrit :
> It did not occur to me initially, but all I had to do was add
> +dx/dy/dz terms in the Helmert string for NOAM in the init file. It
> works perfectly.
> *From:* Steve Riddell
> *Sent:* Wednesday, February 9, 2022 3:43 PM
> *To:* Even Rouault <even.rouault at spatialys.com>; proj at lists.osgeo.org
> *Cc:* Kristian Evers <kreve at sdfe.dk>
> *Subject:* RE: [PROJ] Plate motion models
> Thank you again for the assistance. That was a huge help. It works as
> expected, based on the delivered ITRF2008/ITRF2014 init files.
> Perhaps it should be noted that the delivered models support only
> 3-rotation parameters. The paper, “ITRF2008 plate motion model, Z.
> Altamimi, et al.”, and the HTDP documentation indicates that plates
> NOAM, PCFC, and CARB, include translation rates as well:
> (0.41,0.22,0.41)mm/yr.  The practical difference then is
> sub-centimeter, but noticeable when comparing with HTDP (over areas
> not covered by HTDP’s velocity grids).
> Thanks again,
> steve
> *From:* Even Rouault <even.rouault at spatialys.com>
> *Sent:* Monday, February 7, 2022 9:18 AM
> *To:* Steve Riddell <sriddell at geocue.com>; proj at lists.osgeo.org
> *Subject:* Re: [PROJ] Plate motion models
> Hi Steve,
> Assuming lon=-100 lat=40 z=0,  I believe (not sure! and in particular
> if that's geodetically meaningful to chain so many transformations)
> you should use a pipeline like the following one, which will do:
> - conversion to cartesian coordinate space
> - apply the ITRF2000 to ITRF2014 transformation preserving observation
> epoch of 2022.1
> - apply the ITRF2014:NOAM model using a target epoch of 2010 (hence
> the +inv, as naturally the transformation would use +t_epoch as the
> "source") for a point at observation epoch of 2022.1
> - force the observation epoch to 2010
> - apply the ITRF2014 to ITRF2000 transformation (at epoch 2010)
> - conversion to lat, lon coordinate space
> echo -100 40 0 2022.1 | cct -d 8 +proj=pipeline \
>     +step +proj=cart +ellps+GRS80 \
>     +step +inv +init=ITRF2014:ITRF2000 \
>     +step +inv +init=ITRF2014:NOAM +t_epoch=2010 \
>     +step +proj=set +v_4=2010 \
>     +step +init=ITRF2014:ITRF2000 \
>     +step +inv +proj=cart +ellps+GRS80
> I get:
> -99.99999790     40.00000064 0.00755196     2010.0000
> If using ITRF2008 instead of ITRF2014, I get:
>   -99.99999854     40.00000065    0.00909276     2010.0000
> I've also tried using a plate-fixed CRS as an intermediate using what
> is available in EPSG
> First with NAD83(CORS96) since there's a direct transformation for it
> in EPSG (not quite "direct" since when looking at the comments, it
> already results from concatenation of ITRF96>97 and IERS ITRF97>2000
> transformations)
> (order is lat, lon here)
> $ echo 40 -100 0 2022.1 | cs2cs -d 8 "ITRF2000" "NAD83(CORS96)" | cct
> -d 8 +proj=set +v_4=2010 | cs2cs -d 8 "NAD83(CORS96)"  "ITRF2000"
> 40.00000067    -99.99999766 -0.00447640     2010.0000
> Or if using NAD83(2011) (there's a transformation between NAD83(2011)
> and ITRF2008 in EPSG (concatenation of ITRF96>97 and IERS ITRF97>2008
> transformations), and PROJ will use the ITRF2008 to ITRF2000
> transformation in addition
> $ echo 40 -100 0 2022.1 | cs2cs -d 8 "ITRF2000" "NAD83(2011)" | cct -d
> 8 +proj=set +v_4=2010 | cs2cs -d 8 "NAD83(2011)"  "ITRF2000"
> 40.00000066    -99.99999765 -0.00447668     2010.0000
> So results are somewhat consistent, at least in the lat, lon space
> (not for z values)
> Best regards,
> Even
> Le 07/02/2022 à 14:49, Steve Riddell a écrit :
>     The data for the ITFR2008 & ITRF2014 plate motion models are
>     delivered with PROJ as init files. From the documentation, 8.7, I
>     think I see how an +init proj string can be used for changing
>     epochs between ITFR frames (e.g. ITRF2000 to ITRF2005), but can
>     someone please give an example of using the plate models? For
>     example, if I have a point in ITRF2000 epoch 2022.1 and I want to
>     use the NOAM plate model to move it to 2010.0, what would be the
>     +init string? I’m assuming cct would be an appropriate application
>     for processing this string?
>     Thanks for any assistance!
>     Steve
>     _______________________________________________
>     PROJ mailing list
>     PROJ at lists.osgeo.org
>     https://lists.osgeo.org/mailman/listinfo/proj
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20220211/e8b5073c/attachment-0001.html>
More information about the PROJ mailing list
