[PROJ] PROJ 9.0.0RC1 & PROJ-data 1.9RC1
Sebastiaan Couwenberg sebastic at xs4all.nl
Tue Feb 15 13:15:29 PST 2022
On 2/15/22 22:13, Even Rouault wrote:
> Bas,
>> The gtest download doesn't work for the Debian package as the build
>> environment doesn't have network:
> installing the "libgtest-dev" package will solve that if you want to
> build & run the tests. Otherwise run cmake with -DBUILD_TESTING=OFF to
> disable them
This was not required before.
test/unit/CMakeLists.txt causes the gtest download, but it seems already
to be present in test/googletest, shouldn't that be used instead?
Kind Regards,
Bas
  GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
More information about the PROJ mailing list
