[PROJ] Does WGS84 automatically use EGM96 in PROJ?
Clifford J Mugnier cjmce at lsu.edu
Mon Jan 10 15:10:08 PST 2022
Apples and oranges.  ECEF to ENU is a purely geometric transformation.  Earth Gravity Models have no relationship in such a transformation.
Clifford J. Mugnier, c.p., c.m.s.
Chief of Geodesy, Emeritus
LSU Center for GeoInformatics (ERAD 266)
Dept. of Civil Engineering
LOUISIANA STATE UNIVERSITY
Baton Rouge, LA  70803
Research:   (225) 578-4578
Cell:           (225) 328-8975
honorary lifetime member, lsps
fellow emeritus, asprs
member, apsg
From: PROJ <proj-bounces at lists.osgeo.org> on behalf of Andrew Kelley <akelley2500 at gmail.com>
Sent: Monday, January 10, 2022 3:54 PM
To: proj at lists.osgeo.org <proj at lists.osgeo.org>
Subject: [PROJ] Does WGS84 automatically use EssGM96 in PROJ?
Hello,
My team is using PROJ to convert ECEF coordinates to ENU coordinates (relative to a fixed point on the surface of the Earth). When we use WGS84 for this, does that automatically use EGM96? What makes me think EGM96 is used is that one website I found<http://wiki.gis.com/wiki/index.php/WGS84> says, "Presently WGS 84 uses the 1996 Earth Gravitational Model (EGM96) geoid, revised in 2004."  But I found out elsewhere online<https://en.wikipedia.org/wiki/Earth_Gravitational_Model> that there is an EGM84, EGM96, and an EGM2008.
Note: We are currently using proj-strings, though we would be happy to use object codes (ie. EPSG:XXXX) if we knew how to specify the origin of the ENU coordinates when using an object code.
Thank you for your time,
Andrew Kelley
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20220110/88e2d6fa/attachment.html>
More information about the PROJ mailing list
