[PROJ] missing docker image osgeo/proj:8.2.1
Javier Jimenez Shaw j1 at jimenezshaw.com
Wed Jan 12 02:05:20 PST 2022
I realized that the automatic link to hub.docker.com was not including the
trailing dot (at least my mail client).
So you can add the "." in the query manually, or maybe use this stricter
filter:
https://hub.docker.com/r/osgeo/proj/tags?page=1&name=8.2
Maybe I shouldn't assume that tagged docker images are in the release
process. I was using them to update
https://github.com/jjimenezshaw/crs-explorer after every release.
Thanks.
.___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
On Sat, 8 Jan 2022 at 23:22, Javier Jimenez Shaw <j1 at jimenezshaw.com> wrote:
> Hi
> Trying to pull the docker image for version 8.2.1, I got an error
> $ docker pull osgeo/proj:8.2.1
> Error response from daemon: manifest for osgeo/proj:8.2.1 not found:
> manifest unknown: manifest unknown
> checking in hub.docker.com, I found it is not there:
> The last tagged versioned is 8.2.0
> Is there any reason for that?
> Are docker images part of the release process?
> note: tags 8.1.1 and 8.2.0 were pushed by user 'hobu', while the previous
> tags by 'osgeo'
> Thanks.
> Javier
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20220112/078a39ce/attachment.html>
More information about the PROJ mailing list
