[PROJ] missing docker image osgeo/proj:8.2.1
Even Rouault even.rouault at spatialys.com
Wed Jan 12 08:21:30 PST 2022
I've manually pushed the image. The github action job that normally does
that automatically
(https://github.com/OSGeo/PROJ/actions/runs/1643807473) broke for
another reason (proj-docs build failure, that has been solved afterwards)
Le 12/01/2022 à 11:05, Javier Jimenez Shaw a écrit :
> I realized that the automatic link to hub.docker.com
> <http://hub.docker.com> was not including the trailing dot (at least
> my mail client).
> So you can add the "." in the query manually, or maybe use this
> stricter filter:
> https://hub.docker.com/r/osgeo/proj/tags?page=1&name=8.2
> <https://hub.docker.com/r/osgeo/proj/tags?page=1&name=8.2>
> Maybe I shouldn't assume that tagged docker images are in the release
> process. I was using them to update
> https://github.com/jjimenezshaw/crs-explorer
> <https://github.com/jjimenezshaw/crs-explorer> after every release.
> Thanks.
> .___ ._ ..._ .. . ._. .___ .. __ . _. . __..  ... .... ._ .__
> Entre dos pensamientos racionales
> hay infinitos pensamientos irracionales.
> On Sat, 8 Jan 2022 at 23:22, Javier Jimenez Shaw <j1 at jimenezshaw.com
> <mailto:j1 at jimenezshaw.com>> wrote:
>     Hi
>     Trying to pull the docker image for version 8.2.1, I got an error
>     $ docker pull osgeo/proj:8.2.1
>     Error response from daemon: manifest for osgeo/proj:8.2.1 not
>     found: manifest unknown: manifest unknown
>     checking in hub.docker.com <http://hub.docker.com>, I found it is
>     not there:
>     <https://hub.docker.com/r/osgeo/proj/tags?page=1&name=8>.
>     The last tagged versioned is 8.2.0
>     Is there any reason for that?
>     Are docker images part of the release process?
>     note: tags 8.1.1 and 8.2.0 were pushed by user 'hobu', while the
>     previous tags by 'osgeo'
>     Thanks.
>     Javier
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20220112/f67c5a8f/attachment.html>
More information about the PROJ mailing list
