[PROJ] missing docker image osgeo/proj:8.2.1
Javier Jimenez Shaw j1 at jimenezshaw.com
Wed Jan 12 08:23:06 PST 2022
Thanks!
.___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
On Wed, 12 Jan 2022 at 17:21, Even Rouault <even.rouault at spatialys.com>
wrote:
> I've manually pushed the image. The github action job that normally does
> that automatically (https://github.com/OSGeo/PROJ/actions/runs/1643807473)
> broke for another reason (proj-docs build failure, that has been solved
> afterwards)
> Le 12/01/2022 à 11:05, Javier Jimenez Shaw a écrit :
> I realized that the automatic link to hub.docker.com was not including
> the trailing dot (at least my mail client).
> So you can add the "." in the query manually, or maybe use this stricter
> filter:
> https://hub.docker.com/r/osgeo/proj/tags?page=1&name=8.2
> Maybe I shouldn't assume that tagged docker images are in the release
> process. I was using them to update
> https://github.com/jjimenezshaw/crs-explorer after every release.
> Thanks.
> On Sat, 8 Jan 2022 at 23:22, Javier Jimenez Shaw <j1 at jimenezshaw.com>
> wrote:
>> Hi
>> Trying to pull the docker image for version 8.2.1, I got an error
>> $ docker pull osgeo/proj:8.2.1
>> Error response from daemon: manifest for osgeo/proj:8.2.1 not found:
>> manifest unknown: manifest unknown
>> checking in hub.docker.com, I found it is not there:
>> The last tagged versioned is 8.2.0
>> Is there any reason for that?
>> Are docker images part of the release process?
>> note: tags 8.1.1 and 8.2.0 were pushed by user 'hobu', while the previous
>> tags by 'osgeo'
>> Thanks.
>> Javier
> PROJ mailing listPROJ at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/proj
> -- http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20220112/0b463ec3/attachment.html>
More information about the PROJ mailing list
