[PROJ] Fwd: some help with cm-level GRS80 to WGS-84 transformation?
Lesparre, Jochem Jochem.Lesparre at kadaster.nl
Wed Jan 19 13:03:39 PST 2022
Dear Joe,
For this case in cs2cs you have to add a +towgs84 parameter too. If you don’t want a datum transformation: +towgs84=0,0,0,0,0,0,0 on both sides.
Regards, Jochem
From: PROJ <proj-bounces at lists.osgeo.org> On Behalf Of Joseph Boardman
Sent: woensdag 19 januari 2022 21:25
To: proj at lists.osgeo.org
Subject: [PROJ] Fwd: some help with cm-level GRS80 to WGS-84 transformation?
-------- Forwarded Message --------
Subject:
Date:
Wed, 19 Jan 2022 11:28:24 -0700
Joseph Boardman <boardman at aigllc.com><mailto:boardman at aigllc.com>
To:
proj at lists.osgeo.org<mailto:proj at lists.osgeo.org>
Dear Proj Experts,
I'm a remote sensing geophysicist with experience in geodesy and mapping.
Right now I'm struggling trying to get a high-accuracy proj command to convert from GRS80 to WGS-84 at the cm level.
Any clues? cs2cs is not doing it.
cs2cs +proj=lonlat +ellps=WGS84 +to +proj=lonlat +ellps=GRS80 -d 8
-120 40
-120.00000000   40.00000000 0.00000000
Do I need to do a transformation pipeline per the 8.2.1 docs and use a Helmert transform? Any help much appreciated.
Best,
Joe
Disclaimer:
De inhoud van deze e-mail is vertrouwelijk en uitsluitend bestemd voor de geadresseerde(n).
Gebruik, openbaarmaking, vermenigvuldiging, verspreiding en/of verstrekking van deze informatie aan derden is niet toegestaan.
Op al onze producten en diensten zijn onze algemene leveringsvoorwaarden van toepassing
[https://www.kadaster.nl/algemene-leveringsvoorwaarden].
Disclaimer:
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you are not the intended recipient, you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Our general terms and conditions of delivery apply to all our products and services
[https://www.kadaster.com/general-terms-and-conditions].
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20220119/c3fe62bb/attachment-0001.html>
More information about the PROJ mailing list
