[PROJ] confidence % in projinfo --identify
Even Rouault even.rouault at spatialys.com
Fri Jul 1 10:47:47 PDT 2022
Le 01/07/2022 à 19:16, Javier Jimenez Shaw a écrit :
> Hi
> I am a bit confused with "--identify" option in projinfo. I looked at
> the documentation of the method "identify" of CRS classes in C++
> trying to understand.
> Running
> projinfo "$(projinfo ESRI:102654 -o WKT1:GDAL -q)" --identify -o WKT1:GDAL
> Produces
> PROJCS["NAD_1983_StatePlane_Colorado_Central_FIPS_0502_Feet (deprecated)",
> Identification match count: 1
> ESRI:102654: 100 %
> so far so good.
"projinfo ESRI:102654 -o WKT1:GDAL -q" generates a WKT with the
ESRI:102654 authority node, hence it is used for identification
> Running (I just changed the wkt1 dialect in the inner call)
> projinfo "$(projinfo ESRI:102654 -o WKT1:ESRI -q)" --identify -o WKT1:GDAL
> Produces
> PROJCS["NAD83 / Colorado Central (ftUS)",
> EPSG:2232: 100 %
> Looking at the C++ documentation I think that a confidence of 100%
> means that the names are the same (I do not really know which names it
> refers to. Only the CRS name? geographic crs? datum? units? anything
> else? all?)
"projinfo ESRI:102654 -o WKT1:ESRI -q" strips the authority node (this
is canonical for ESRI WKT), so for identification PROJ relies on the CRS
name (to start with). The reason to match EPSG:2232 here is this entry
in the database:
../data/sql/esri.sql:INSERT INTO alias_name
VALUES('projected_crs','EPSG','2232','NAD_1983_StatePlane_Colorado_Central_FIPS_0502_Feet','ESRI');
which is added when importing the ESRI database where they link their
deprecated code to the EPSG entry
I'm not sure to remember why it chooses the entry corresponding to the
alias rather than ESRI:102654. Probably the fact that ESRI:102654 is
deprecated.
> If I use this WKT string (the ESRI one, but adding the authority at
> the end -I found it somewhere-)
> PROJCS["NAD_1983_StatePlane_Colorado_Central_FIPS_0502_Feet",
> GEOGCS["GCS_North_American_1983",
> DATUM["D_North_American_1983",
> SPHEROID["GRS_1980",6378137.0,298.257222101]],
> PRIMEM["Greenwich",0.0],
> UNIT["Degree",0.0174532925199433]],
> PROJECTION["Lambert_Conformal_Conic"],
> PARAMETER["False_Easting",3000000.00031608],
> PARAMETER["False_Northing",999999.999996],
> PARAMETER["Central_Meridian",-105.5],
> PARAMETER["Standard_Parallel_1",38.45],
> PARAMETER["Standard_Parallel_2",39.75],
> PARAMETER["Latitude_Of_Origin",37.8333333333333],
>   UNIT["US survey foot",0.304800609601219],
> AUTHORITY["ESRI","102654"]]
> Produces
> ESRI:102654: 100 %
> It is also changing the name to the one in EPSG, returning the ESRI
> code, and with a confidence of 100%
When there's a code and the provided CRS is equivalent to the one built
from the code, the code is trusted.
Regarding the change of name to the one of EPSG, that's due to the
morphing done by PROJ when importing ESRI WKT to use EPSG
CRS/datum/projection method/projection parameter names.  The reverse
morphing is done when exporting to ESRI WKT.
> Is all that intended? Maybe I misunderstood the meaning of the
> confidence percentage.
Overall yes what you observe is intended. It is really difficult to
document every aspect of what some functions does, as there are a lot of
heuristics added to make things work smoothly and describing everything
can be confusing (and here there are considerations related to
import/export of ESRI WKT in additions of purely identification issues).
But documentation contributions that could makes things clearer are
welcome. Perhaps the doc could be modified to indicate that 100% also
takes into account registered alias names.
> Thanks.
> .___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
> Entre dos pensamientos racionales
> hay infinitos pensamientos irracionales.
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20220701/8e1d9d5c/attachment.htm>
More information about the PROJ mailing list
