[PROJ] Affine transformation using DERIVEDPROJCRS
Bart.Duijndam at ziggo.nl Bart.Duijndam at ziggo.nl
Mon Jul 4 02:00:27 PDT 2022
Greetings all,
Working with QGIS, I am in need of developing a ‘custom CRS’ with its own origin and orientation.
Basically I need a CRS that is DERIVED from a PROJCRS, resulting in a DERIVEDPROJCRS.
I have done some work to that extent, that can be seen at the following spreadsheet on GitHub:
https://github.com/Duijndam-Dev/TopoLib/blob/master/TopoLib/Samples/DerivedProjectedCrsTests.xlsb
Right now, I do this by hacking a WKT2 string, based on various examples found on the internet.
https://gis.stackexchange.com/questions/353022/defining-a-coordinate-system-in-wkt-or-proj-format-that-has-an-affine-transforma
https://gis.stackexchange.com/questions/350228/define-custom-projection-in-qgis-from-some-control-points
https://gis.stackexchange.com/questions/408406/qgis-custom-projection-in-wkt-not-saving-prj-file
https://gis.stackexchange.com/questions/366578/custom-crs-for-historic-site-grid
https://gis.stackexchange.com/questions/408683/custom-derived-crs-by-affine-transformation-from-epsg32633-setting-as-layer-cr
Doing the required affine transform is relatively straightforward. What is more of a concern is creating a WKT2 string to setup the DERIVEDPROJCRS.
In particular, I would like to preserve the USAGE definition and BBOX field. Any closing ID field needs to be removed, as it is no longer valid.
But the process of editing a WKT2 string is rather error prone. It is not something you’d like a ‘novice’ having to do.
Now, the fact is that proj supports affine transforms since v6.0.0. See: https://proj.org/operations/transformations/affine.html?highlight=affine+transformation#
Finally, to come to my question: would it be possible to define the following workflow in C++ code:
1.	Create a projected CRS object (from EPSG code, or a WKT string)
2.	Apply an affine transformation on this CRS
3.	Export the modified CRS as a WKT string
This automation would avoid any manual editing of the WKT2 string.
Maybe - if this isn’t the best approach - are any other ways conceivable to achieve my goal ?
Much appreciate your advice.
 <mailto:Bart.Duijndam at ziggo.nl> Bart Duijndam
Geoscience consultant
www.duijndam.dev <http://www.duijndam.dev/>
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20220704/91e86983/attachment.htm>
More information about the PROJ mailing list
