[PROJ] Affine transformation using DERIVEDPROJCRS
Even Rouault even.rouault at spatialys.com
Sat Jul 9 07:13:07 PDT 2022
Le 09/07/2022 à 16:05, Bart.Duijndam at ziggo.nl a écrit :
> Hi Even,
> You mentioned that in order to have ID["EPSG",9624]]included into the
> WKT2 string, you need to add it to the PropertyMap with
> .set(metadata::Identifier::CODESPACE_KEY, metadata::Identifier::EPSG)
> .set(metadata::Identifier::CODE_KEY, 9624)
> I appreciate this, but the question is *where* do this.
Well, on the object where this is relevant :-)
So on the property map of the conversion method, that is the one of
PropertyMap().set(IdentifiedObject::NAME_KEY, "Affine parametric
transformation"),
> Obviously, I have similar problems with the Affine transformation
> parameters: 8623, 8624, 8625, 8639, 8640 and 8641.
Same here on the respective property map of each operation parameter.
so something like
Conversion::create
          PropertyMap().set(IdentifiedObject::NAME_KEY, "Affine"),
parametric transformation").set(metadata::Identifier::CODESPACE_KEY,
metadata::Identifier::EPSG).set(metadata::Identifier::CODE_KEY, 9624) ,
          std::vector<OperationParameterNNPtr>
              OperationParameter::create(PropertyMap().set(
"A0").set(metadata::Identifier::CODESPACE_KEY,
metadata::Identifier::EPSG).set(metadata::Identifier::CODE_KEY, 8623)),
                  IdentifiedObject::NAME_KEY, "A1")),
                  IdentifiedObject::NAME_KEY, "A2")),
                  IdentifiedObject::NAME_KEY, "B0")),
                  IdentifiedObject::NAME_KEY, "B1")),
                  IdentifiedObject::NAME_KEY, "B2")),
> Kind regards,
> Bart
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20220709/6a49d90b/attachment-0001.htm>
More information about the PROJ mailing list
