[PROJ] Affine transformation using DERIVEDPROJCRS
Bart.Duijndam at ziggo.nl Bart.Duijndam at ziggo.nl
Sat Jul 9 09:01:14 PDT 2022
Hi Even,
Merci beaucoup; ça marche !
Bart
Sent: Saturday, 9 July 2022 16:13
To: Bart.Duijndam at ziggo.nl; proj at lists.osgeo.org
Subject: Re: [PROJ] Affine transformation using DERIVEDPROJCRS
Le 09/07/2022 à 16:05, Bart.Duijndam at ziggo.nl <mailto:Bart.Duijndam at ziggo.nl>  a écrit :
Hi Even,
You mentioned that in order to have ID["EPSG",9624]] included into the WKT2 string, you need to add it to the PropertyMap with
    .set(metadata::Identifier::CODESPACE_KEY, metadata::Identifier::EPSG)
    .set(metadata::Identifier::CODE_KEY, 9624)
I appreciate this, but the question is *where* do this.
Well, on the object where this is relevant :-)
So on the property map of the conversion method, that is the one of
PropertyMap().set(IdentifiedObject::NAME_KEY, "Affine parametric transformation"),
Obviously, I have similar problems with the Affine transformation parameters: 8623, 8624, 8625, 8639, 8640 and 8641.
Same here on the respective property map of each operation parameter.
so something like
Conversion::create
         PropertyMap().set(IdentifiedObject::NAME_KEY, "Affine"),
         PropertyMap().set(IdentifiedObject::NAME_KEY, "Affine parametric transformation") .set(metadata::Identifier::CODESPACE_KEY, metadata::Identifier::EPSG).set(metadata::Identifier::CODE_KEY, 9624) ,
         std::vector<OperationParameterNNPtr>
             OperationParameter::create(PropertyMap().set(
                 IdentifiedObject::NAME_KEY, "A0") .set(metadata::Identifier::CODESPACE_KEY, metadata::Identifier::EPSG).set(metadata::Identifier::CODE_KEY, 8623)),
                 IdentifiedObject::NAME_KEY, "A1")),
                 IdentifiedObject::NAME_KEY, "A2")),
                 IdentifiedObject::NAME_KEY, "B0")),
                 IdentifiedObject::NAME_KEY, "B1")),
                 IdentifiedObject::NAME_KEY, "B2")),
Kind regards,
Bart
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20220709/c311b073/attachment.htm>
More information about the PROJ mailing list
