[PROJ] Intermediate steps due same datum transformation
Oleg Bizin oleg.bizin87 at gmail.com
Tue Jul 19 23:27:24 PDT 2022
Ok, now everything is clear.
Thanks!
вт, 19 июл. 2022 г. в 18:10, Even Rouault <even.rouault at spatialys.com>:
> Le 19/07/2022 à 17:02, Oleg Bizin a écrit :
> Even,
> Thank you for the detailed answer!
> I have a couple more clarifying questions.
> More generally PROJ >= 6 will not use WGS 84 as a compulsory pivot in
>> coordinate transformations
> 1. Is it correct that the  PROJ < 6 definitely uses WGS84 as a compulsory
> pivot?
> When there was a datum indication in the PROJ.4 string, yes, since
> +towgs84 or +nadgrids implied the WGS84 pivot. When source and
> transformation CRS PROJ.4 strings used the same +towgs84 terms, that was
> skipped as an optimization (what newer PROJ does too)
> 2. Currently, before your fix, for custom crs transformation to WGS84 may
> perform, but  without significant impact on accuracy?
> For most uses yes, it shouldn't have significant impact. Unless you
> transformation coordinates back and forth many many times.
> -- http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20220720/3a0d0152/attachment.htm>
More information about the PROJ mailing list
