[PROJ] Affine transformation for engineering crs
Torill Kjøsnes Gabrielsen torill.kjosnes at gmail.com
Wed Jun 1 04:03:01 PDT 2022
I have an engineering crs that I would like to transform with an affine
transformation.
The transformation for the crs is defined in 9624:
https://epsg.org/coord-operation-method_9624/Affine-parametric-transformation.html
The coordinate transformation parameter values are:
A0 = 82357.457 metres
A1 = 0.304794369
A2 = 0.000015417425
B0 = 28091.324 metres
B1 = -0.000015417425
B2 = 0.304794369
Is there anyone who can help me address which parameters correspond to those
defined in PROJ affine?
A0 = +xoff?
A1 = +s11?
A2 = ?
B0 = +yoff?
B1 = +s22?
B2 = ?
Regards,
Torill Gabrielsen
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20220601/b1993d3b/attachment.htm>
More information about the PROJ mailing list
