[PROJ] PROJ 9.0.1RC2 & PROJ-data 1.10RC1
Even Rouault even.rouault at spatialys.com
Mon Jun 13 15:27:05 PDT 2022
+1 Even
Le 14/06/2022 à 00:24, Kristian Evers a écrit :
> No issues of big concern has been raised with the release candidates,
> so I hereby motion they be promoted to final releases.
> I’ll start with my +1.
> /Kristian
>> On 8 Jun 2022, at 19.50, Kristian Evers <kristianevers at gmail.com> wrote:
>> All,
>> I have prepared release candidates for PROJ 9.0.1 and PROJ-data 1.10. Due to a slight
>> hiccup with PROJ 9.0.0RC1 before it was announced we are going more or less straight
>> to RC2 as to not disturb those who managed to download it right away. The PROJ release
>> notes can be found at the bottom of this email.
>> The PROJ-data package includes a metadata correction for some Dutch grids and adds
>> a Norwegian transformation grid as an extension to the NKG transformations.
>> Download the release candidates here:
>> https://download.osgeo.org/proj/proj-9.0.1RC2.tar.gz
>> https://download.osgeo.org/proj/proj-9.0.1RC2.zip
>> https://download.osgeo.org/proj/proj-data-1.10RC1.tar.gz
>> https://download.osgeo.org/proj/proj-data-1.10RC1.zip
>> As always, please report any issues you find in the release candidates either here or
>> on GitHub.
>> /Kristian
>> 9.0.1 Release Notes
>> Database updates
>> o Update to EPSG 10.064 (#3208)
>> o Add OGC:CRS84h (WGS 84 longitude-latitude-height) (#3155)
>> Bug fixes
>> o Use CMAKE_INSTALL_MANDIR to override default (#3081)
>> o Increase MAX_ITER so Mollweide forward projection works near the poles (#3082)
>> o Fix wrong results with SQLite 3.38.0 (#3091)
>> o Fix issue when transforming from/to BoundCRS of 3D CRS with non-Greenwhich
>>   prime meridian, created from WKT (#3098)
>> o Fix issues with WKT of concatenated operations (#3105)
>> o CMake: fix installation of proj.pc on Windows (#3109)
>> o createOperations(): fix issue in transformation northing, easting
>>    projected CRS -> +proj=longlat +lon_wrap (#3110)
>> o unitconvert: round to nearest date when converting to yyyymmdd (#3111)
>> o Fix comparison of GeodeticRefrenceFrame vs DynamicGeodeticReferenceFrame (#3120)
>> o createOperations(): fix transformation involving CompoundCRS, ToWGS84
>>    and PROJ4_GRIDS (#3124)
>> o Fix datum names when importing from PROJ4 crs strings (affects some
>>    transformations using geoidgrids) (#3129)
>> o Deal with PARAMETER["EPSG code for Interpolation CRS",crs_code] (#3149)
>> o createOperations(): fix CompoundCRS[BoundCRS[ProjectedCRS],BoundCRS[VerticalCRS]]
>>    to Geog3DCrs (#3151)
>> o ITRF2014: fix ITRF2014:ITRF88,ITRF94 and ITRF96 definitions (#3159)
>> o createBoundCRSToWGS84IfPossible(): improve selection logic to generate +towgs84=
>>    taking into account extent (#3160)
>> o createOperations(): fix some complex cases involving TOWGS84 and CompoundCRS (#3163)
>> o Fix cmake CURL dependency, update appveyor - vcpkg interaction (#3185)
>> o WKT import: deal with Projected CRS that is a mix of WKT1:GDAL / WKT1:ESRI (#3189)
>> o createOperations(): fix/improve result of 'BD72 + Ostend height ' to 'WGS84+EGM96 height' (#3199)
>> o Identifier::isEquivalentName(): fix when ending by ' + ' which could indirectly cause
>>    an infinite stack call in master (#3202)
>> o WKT import: correctly deal with absence of Latitude_Of_Origin parameter in
>>    WKT1 ESRI with Stereographic projection (#3212)
>> o PROJJSON parser: do not error out if a datum ensemble member is unknown in the database (#3223)
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
More information about the PROJ mailing list
