[PROJ] PROJ 9.0.1RC2 & PROJ-data 1.10RC1
Thomas Knudsen knudsen.thomas at gmail.com
Tue Jun 14 02:50:15 PDT 2022
+1 Thomas
Den tir. 14. jun. 2022 kl. 00.24 skrev Kristian Evers <
kristianevers at gmail.com>:
> No issues of big concern has been raised with the release candidates,
> so I hereby motion they be promoted to final releases.
> I’ll start with my +1.
> /Kristian
> > On 8 Jun 2022, at 19.50, Kristian Evers <kristianevers at gmail.com> wrote:
> > All,
> > I have prepared release candidates for PROJ 9.0.1 and PROJ-data 1.10.
> Due to a slight
> > hiccup with PROJ 9.0.0RC1 before it was announced we are going more or
> less straight
> > to RC2 as to not disturb those who managed to download it right away.
> The PROJ release
> > notes can be found at the bottom of this email.
> > The PROJ-data package includes a metadata correction for some Dutch
> grids and adds
> > a Norwegian transformation grid as an extension to the NKG
> transformations.
> > Download the release candidates here:
> > https://download.osgeo.org/proj/proj-9.0.1RC2.tar.gz
> > https://download.osgeo.org/proj/proj-9.0.1RC2.zip
> > https://download.osgeo.org/proj/proj-data-1.10RC1.tar.gz
> > https://download.osgeo.org/proj/proj-data-1.10RC1.zip
> > As always, please report any issues you find in the release candidates
> either here or
> > on GitHub.
> > /Kristian
> > 9.0.1 Release Notes
> > Database updates
> > o Update to EPSG 10.064 (#3208)
> > o Add OGC:CRS84h (WGS 84 longitude-latitude-height) (#3155)
> > Bug fixes
> > o Use CMAKE_INSTALL_MANDIR to override default (#3081)
> > o Increase MAX_ITER so Mollweide forward projection works near the poles
> (#3082)
> > o Fix wrong results with SQLite 3.38.0 (#3091)
> > o Fix issue when transforming from/to BoundCRS of 3D CRS with
> non-Greenwhich
> >  prime meridian, created from WKT (#3098)
> > o Fix issues with WKT of concatenated operations (#3105)
> > o CMake: fix installation of proj.pc on Windows (#3109)
> > o createOperations(): fix issue in transformation northing, easting
> >   projected CRS -> +proj=longlat +lon_wrap (#3110)
> > o unitconvert: round to nearest date when converting to yyyymmdd (#3111)
> > o Fix comparison of GeodeticRefrenceFrame vs
> DynamicGeodeticReferenceFrame (#3120)
> > o createOperations(): fix transformation involving CompoundCRS, ToWGS84
> >   and PROJ4_GRIDS (#3124)
> > o Fix datum names when importing from PROJ4 crs strings (affects some
> >   transformations using geoidgrids) (#3129)
> > o Deal with PARAMETER["EPSG code for Interpolation CRS",crs_code] (#3149)
> CompoundCRS[BoundCRS[ProjectedCRS],BoundCRS[VerticalCRS]]
> >   to Geog3DCrs (#3151)
> > o ITRF2014: fix ITRF2014:ITRF88,ITRF94 and ITRF96 definitions (#3159)
> > o createBoundCRSToWGS84IfPossible(): improve selection logic to generate
> +towgs84=
> >   taking into account extent (#3160)
> > o createOperations(): fix some complex cases involving TOWGS84 and
> CompoundCRS (#3163)
> > o Fix cmake CURL dependency, update appveyor - vcpkg interaction (#3185)
> > o WKT import: deal with Projected CRS that is a mix of WKT1:GDAL /
> WKT1:ESRI (#3189)
> > o createOperations(): fix/improve result of 'BD72 + Ostend height ' to
> 'WGS84+EGM96 height' (#3199)
> > o Identifier::isEquivalentName(): fix when ending by ' + ' which could
> indirectly cause
> >   an infinite stack call in master (#3202)
> > o WKT import: correctly deal with absence of Latitude_Of_Origin
> parameter in
> >   WKT1 ESRI with Stereographic projection (#3212)
> > o PROJJSON parser: do not error out if a datum ensemble member is
> unknown in the database (#3223)
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20220614/6a017056/attachment.htm>
More information about the PROJ mailing list
