[PROJ] Proj for Windows
Even Rouault even.rouault at spatialys.com
Thu Jun 30 03:31:21 PDT 2022
Not standalone installers, but you can easily get recent PROJ binaries
for Windows from Conda or vcpkg for example: https://proj.org/install.html
the Trac wiki link you mention is outdated. OSGeo4W PROJ binaries are at
http://download.osgeo.org/osgeo4w/v2/x86_64/release/proj/ (that you'll
download using the OSGeo4W installer
(https://trac.osgeo.org/osgeo4w/#QuickStartforOSGeo4WUsers) and their
build recipee at
https://github.com/jef-n/OSGeo4W/tree/master/src/proj/osgeo4w
Le 30/06/2022 à 12:04, Roger Oberholtzer a écrit :
> Hi all,
> I usually use proj on Linux. Specifically, openSUSE. All is working great.
> openSUSE have a build service where I had been building proj for
> Widows. Nice service. Interestingly, it makes an RPM of the Windows
> package. Which actually works fine for me as I ma only after the
> files. But I digress.
> Anyway, the last one I built that way was 4.9. It's obviously time for
> an update!
> The installable components of 4.9 were rather small. So we could
> include the needed components in our installer. Newer proj releases
> potentially have more that can be installed.
> So I'm guessing that a separate proj installer would be a better
> choice. Before re-inventing the wheel, I thought I would see if there
> already is a Windows installer. Which took me here:
> https://trac.osgeo.org/osgeo4w/wiki/pkg-proj
> Seems that the link to any install files no longer exists. Is that a
> stale link? Or is it no longer something that will be available?
> If it's not going to be available, I will update the following to make
> RPMs with the needed files. And then make installers from that. But a
> general release seems like a good idea.
> If you are curious:
> My Windows port (old!):
> https://build.opensuse.org/package/show/home:rogeroberholtzer:mingw64/mingw64-proj
> OpenSUSE's proj build:
> https://build.opensuse.org/package/show/openSUSE%3AFactory/proj
> The great thing about this service is that if any dependencies change,
> the package is automatically rebuilt. And all packages are available
> in signed repositories. Many Linux distros are supported. Not just
> openSUSE.
> I don't work at SUSE. I'm just passing on info about a potentially
> interesting place to build proj for many platforms.
> Still curious about the missing link mentioned above.
http://www.spatialys.com
More information about the PROJ mailing list
