[PROJ] PROJ 9.1.1RC1 & PROJ-data 1.12RC1
Even Rouault even.rouault at spatialys.com
Fri Nov 25 10:31:13 PST 2022
Hi Kristian,
9.1.1RC1 sucessfully tested against GDAL autotest suite of release/3.6
branch
Even
Le 25/11/2022 à 18:56, Kristian Evers a écrit :
> All,
> I’ve prepared release candidates for PROJ 9.1.1 and PROJ-data 1.12. The PROJ
> release includes a number of bug fixes (release notes below) and a slight update
> to the database. PROJ-data is extended with the at_bev_AT_GIS_GRID_2021_09_28
> grid.
> Download the archives here:
> https://download.osgeo.org/proj/proj-9.1.1RC1.tar.gz
> https://download.osgeo.org/proj/proj-9.1.1RC1.zip
> https://download.osgeo.org/proj/proj-data-1.12RC1.tar.gz
> https://download.osgeo.org/proj/proj-data-1.12RC1.zip
> As always, please test the release candidates and report your findings
> either here on the mailing list on in the issue tracker on GitHub.
> /Kristian
> 9.1.0 Release Notes
>   Updates
>   o Database: register at_bev_AT_GIS_GRID_2021_09_28 grid (#3442)
>   Bug fixes
>   o Implement alterGeodeticCRS and stripVerticalComponent for DerivedProjected (#3482)
>   o Various improvements to handling of DerivedProjectedCRS
>     (#3482, #3477, #3342, #3319, #3317)
>   o Add missing <cstdint> includes (#3459)
>   o cs2cs: better validate value of -W option (#3453)
>   o DatabaseContext::lookForGridInfo(): fix caching of filenames and set
>     correct URLs (#3448)
>   o Database: register in grid_alternatives grids from PROJ-data that have no
>     corresponding transformation record (#3446)
>   o cass projection: fix forward computation of easting (#3433)
>   o Implement Geographic/Vertical Offset conversions (#3413)
>   o vandg projection: handle +over to extend the validity domain outside of
>    |lon|>180deg (#3427)
>   o eqdc projection: avoid floating point division by zero in non-nominal case (#3415)
>   o createOperations(): fix issues when transforming between Geog3D and
>     DerivedGeog3D CRS with Geographic3D offsets method (#3411)
>   o VerticalCRS::_isEquivalentTo(): do not consider VerticalCRS and
>     DerivedVerticalCRS as equivalent (#3408)
>   o cct and cs2cs: Avoid problems when encountering UTF-8 BOM characters at
>      beginning of input files (#3395)
>   o createFromUserInput(): Improved lookup when approximate name is provided (#3371)
>   o projinfo / cs2cs : auto promotion to 3D of CRS specified by name (#3367)
>   o findsOpsInRegistryWithIntermediate(): make it work when source/target geodetic
>     CRS has no known id (#3365)
>   o createOperations(): emulate PROJ < 6 behavior when doing geocentric <-->
>     geographic transformation between datum with unknown transformation (#3361)
>   o Fix issue when transforming from/into a WKT2 Bound VerticalCRS with a
>     'Geographic3D to GravityRelatedHeight' method (#3355)
>   o proj_normalize_for_visualization(): take into account FORCE_OVER property
>     from source operation (#3350)
>   o Link geodtest against libm when available (#3341)
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
More information about the PROJ mailing list
