[PROJ] PROJ 9.1.1RC1 & PROJ-data 1.12RC1
Kristian Evers kristianevers at gmail.com
Fri Nov 25 10:59:44 PST 2022
Yes, of course it is. Good catch. If no other issues surface I’ll just make sure to update
the release notes title to 9.1.1 in the final release.
/Kristian
> On 25 Nov 2022, at 19.22, Javier Jimenez Shaw <j1 at jimenezshaw.com> wrote:
> The release notes start with "9.1.0 Release Notes". It is 9.1.1, isn't it?
> .___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
> Entre dos pensamientos racionales
> hay infinitos pensamientos irracionales.
> On Fri, 25 Nov 2022 at 18:56, Kristian Evers <kristianevers at gmail.com <mailto:kristianevers at gmail.com>> wrote:
> All,
> I’ve prepared release candidates for PROJ 9.1.1 and PROJ-data 1.12. The PROJ
> release includes a number of bug fixes (release notes below) and a slight update
> to the database. PROJ-data is extended with the at_bev_AT_GIS_GRID_2021_09_28
> grid.
> Download the archives here:
> https://download.osgeo.org/proj/proj-9.1.1RC1.tar.gz <https://download.osgeo.org/proj/proj-9.1.1RC1.tar.gz>
> https://download.osgeo.org/proj/proj-9.1.1RC1.zip <https://download.osgeo.org/proj/proj-9.1.1RC1.zip>
> https://download.osgeo.org/proj/proj-data-1.12RC1.tar.gz <https://download.osgeo.org/proj/proj-data-1.12RC1.tar.gz>
> https://download.osgeo.org/proj/proj-data-1.12RC1.zip <https://download.osgeo.org/proj/proj-data-1.12RC1.zip>
> As always, please test the release candidates and report your findings
> either here on the mailing list on in the issue tracker on GitHub.
> /Kristian
> 9.1.0 Release Notes
>  Updates
>  o Database: register at_bev_AT_GIS_GRID_2021_09_28 grid (#3442)
>  Bug fixes
>  o Implement alterGeodeticCRS and stripVerticalComponent for DerivedProjected (#3482)
>  o Various improvements to handling of DerivedProjectedCRS
>    (#3482, #3477, #3342, #3319, #3317)
>  o Add missing <cstdint> includes (#3459)
>  o cs2cs: better validate value of -W option (#3453)
>  o DatabaseContext::lookForGridInfo(): fix caching of filenames and set
>    correct URLs (#3448)
>  o Database: register in grid_alternatives grids from PROJ-data that have no
>    corresponding transformation record (#3446)
>  o cass projection: fix forward computation of easting (#3433)
>  o Implement Geographic/Vertical Offset conversions (#3413)
>  o vandg projection: handle +over to extend the validity domain outside of
>   |lon|>180deg (#3427)
>  o eqdc projection: avoid floating point division by zero in non-nominal case (#3415)
>  o createOperations(): fix issues when transforming between Geog3D and
>    DerivedGeog3D CRS with Geographic3D offsets method (#3411)
>  o VerticalCRS::_isEquivalentTo(): do not consider VerticalCRS and
>    DerivedVerticalCRS as equivalent (#3408)
>  o cct and cs2cs: Avoid problems when encountering UTF-8 BOM characters at
>     beginning of input files (#3395)
>  o createFromUserInput(): Improved lookup when approximate name is provided (#3371)
>  o projinfo / cs2cs : auto promotion to 3D of CRS specified by name (#3367)
>  o findsOpsInRegistryWithIntermediate(): make it work when source/target geodetic
>    CRS has no known id (#3365)
>  o createOperations(): emulate PROJ < 6 behavior when doing geocentric <-->
>    geographic transformation between datum with unknown transformation (#3361)
>  o Fix issue when transforming from/into a WKT2 Bound VerticalCRS with a
>    'Geographic3D to GravityRelatedHeight' method (#3355)
>  o proj_normalize_for_visualization(): take into account FORCE_OVER property
>    from source operation (#3350)
>  o Link geodtest against libm when available (#3341)
> PROJ mailing list
> PROJ at lists.osgeo.org <mailto:PROJ at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/proj <https://lists.osgeo.org/mailman/listinfo/proj>
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20221125/e5745953/attachment-0001.htm>
More information about the PROJ mailing list
