[PROJ] PROJ 9.1.1RC1 & PROJ-data 1.12RC1
Kristian Evers kristianevers at gmail.com
Wed Nov 30 12:58:52 PST 2022
Apart from a minor detail in the release notes no issues with the release
candidates has been reported, so I hereby motion they are promoted
to final releases.
I’ll start with my +1.
/Kristian
> On 25 Nov 2022, at 18.56, Kristian Evers <kristianevers at gmail.com> wrote:
> All,
> I’ve prepared release candidates for PROJ 9.1.1 and PROJ-data 1.12. The PROJ
> release includes a number of bug fixes (release notes below) and a slight update
> to the database. PROJ-data is extended with the at_bev_AT_GIS_GRID_2021_09_28
> grid.
> Download the archives here:
> https://download.osgeo.org/proj/proj-9.1.1RC1.tar.gz
> https://download.osgeo.org/proj/proj-9.1.1RC1.zip
> https://download.osgeo.org/proj/proj-data-1.12RC1.tar.gz
> https://download.osgeo.org/proj/proj-data-1.12RC1.zip
> As always, please test the release candidates and report your findings
> either here on the mailing list on in the issue tracker on GitHub.
> /Kristian
> 9.1.0 Release Notes
> Updates
> o Database: register at_bev_AT_GIS_GRID_2021_09_28 grid (#3442)
> Bug fixes
> o Implement alterGeodeticCRS and stripVerticalComponent for DerivedProjected (#3482)
> o Various improvements to handling of DerivedProjectedCRS
>   (#3482, #3477, #3342, #3319, #3317)
> o Add missing <cstdint> includes (#3459)
> o cs2cs: better validate value of -W option (#3453)
> o DatabaseContext::lookForGridInfo(): fix caching of filenames and set
>   correct URLs (#3448)
> o Database: register in grid_alternatives grids from PROJ-data that have no
>   corresponding transformation record (#3446)
> o cass projection: fix forward computation of easting (#3433)
> o Implement Geographic/Vertical Offset conversions (#3413)
> o vandg projection: handle +over to extend the validity domain outside of
>  |lon|>180deg (#3427)
> o eqdc projection: avoid floating point division by zero in non-nominal case (#3415)
> o createOperations(): fix issues when transforming between Geog3D and
>   DerivedGeog3D CRS with Geographic3D offsets method (#3411)
> o VerticalCRS::_isEquivalentTo(): do not consider VerticalCRS and
>   DerivedVerticalCRS as equivalent (#3408)
> o cct and cs2cs: Avoid problems when encountering UTF-8 BOM characters at
>    beginning of input files (#3395)
> o createFromUserInput(): Improved lookup when approximate name is provided (#3371)
> o projinfo / cs2cs : auto promotion to 3D of CRS specified by name (#3367)
> o findsOpsInRegistryWithIntermediate(): make it work when source/target geodetic
>   CRS has no known id (#3365)
> o createOperations(): emulate PROJ < 6 behavior when doing geocentric <-->
>   geographic transformation between datum with unknown transformation (#3361)
> o Fix issue when transforming from/into a WKT2 Bound VerticalCRS with a
>   'Geographic3D to GravityRelatedHeight' method (#3355)
> o proj_normalize_for_visualization(): take into account FORCE_OVER property
>   from source operation (#3350)
> o Link geodtest against libm when available (#3341)
More information about the PROJ mailing list
