[PROJ] PROJ 9.1.1RC1 & PROJ-data 1.12RC1
Even Rouault even.rouault at spatialys.com
Wed Nov 30 13:01:37 PST 2022
+1 Even
Le 30/11/2022 à 21:58, Kristian Evers a écrit :
> Apart from a minor detail in the release notes no issues with the release
> candidates has been reported, so I hereby motion they are promoted
> to final releases.
> I’ll start with my +1.
> /Kristian
>> On 25 Nov 2022, at 18.56, Kristian Evers <kristianevers at gmail.com> wrote:
>> All,
>> I’ve prepared release candidates for PROJ 9.1.1 and PROJ-data 1.12. The PROJ
>> release includes a number of bug fixes (release notes below) and a slight update
>> to the database. PROJ-data is extended with the at_bev_AT_GIS_GRID_2021_09_28
>> grid.
>> Download the archives here:
>> https://download.osgeo.org/proj/proj-9.1.1RC1.tar.gz
>> https://download.osgeo.org/proj/proj-9.1.1RC1.zip
>> https://download.osgeo.org/proj/proj-data-1.12RC1.tar.gz
>> https://download.osgeo.org/proj/proj-data-1.12RC1.zip
>> As always, please test the release candidates and report your findings
>> either here on the mailing list on in the issue tracker on GitHub.
>> /Kristian
>> 9.1.0 Release Notes
>> Updates
>> o Database: register at_bev_AT_GIS_GRID_2021_09_28 grid (#3442)
>> Bug fixes
>> o Implement alterGeodeticCRS and stripVerticalComponent for DerivedProjected (#3482)
>> o Various improvements to handling of DerivedProjectedCRS
>>    (#3482, #3477, #3342, #3319, #3317)
>> o Add missing <cstdint> includes (#3459)
>> o cs2cs: better validate value of -W option (#3453)
>> o DatabaseContext::lookForGridInfo(): fix caching of filenames and set
>>    correct URLs (#3448)
>> o Database: register in grid_alternatives grids from PROJ-data that have no
>>    corresponding transformation record (#3446)
>> o cass projection: fix forward computation of easting (#3433)
>> o Implement Geographic/Vertical Offset conversions (#3413)
>> o vandg projection: handle +over to extend the validity domain outside of
>>   |lon|>180deg (#3427)
>> o eqdc projection: avoid floating point division by zero in non-nominal case (#3415)
>> o createOperations(): fix issues when transforming between Geog3D and
>>    DerivedGeog3D CRS with Geographic3D offsets method (#3411)
>> o VerticalCRS::_isEquivalentTo(): do not consider VerticalCRS and
>>    DerivedVerticalCRS as equivalent (#3408)
>> o cct and cs2cs: Avoid problems when encountering UTF-8 BOM characters at
>>     beginning of input files (#3395)
>> o createFromUserInput(): Improved lookup when approximate name is provided (#3371)
>> o projinfo / cs2cs : auto promotion to 3D of CRS specified by name (#3367)
>> o findsOpsInRegistryWithIntermediate(): make it work when source/target geodetic
>>    CRS has no known id (#3365)
>> o createOperations(): emulate PROJ < 6 behavior when doing geocentric <-->
>>    geographic transformation between datum with unknown transformation (#3361)
>> o Fix issue when transforming from/into a WKT2 Bound VerticalCRS with a
>>    'Geographic3D to GravityRelatedHeight' method (#3355)
>> o proj_normalize_for_visualization(): take into account FORCE_OVER property
>>    from source operation (#3350)
>> o Link geodtest against libm when available (#3341)
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
More information about the PROJ mailing list
