[PROJ] Bugs in PROJ_LIB handling?
Tom O'Reilly oreilly at mbari.org
Wed Oct 5 13:44:11 PDT 2022
How exactly is $PROJ_LIB intended to alter the PJ_INFO.searchpath? It appears to behave differently between PROJ-7.1.0 and PROJ-8.1.0:
PROJ-7.1.0 replaces the last element of PJ_INFO.searchpath with $PROJ_LIB
PROJ-8.1.0 does not add the contents of $PROJ_LIB environment variable to PJ_INFO.searchpath.
(These are the only two PROJ versions I've tested so far)
I determined this behavior from this simple program:
#include <iostream>
#include <proj.h>
int main(int argc, char **argv) {
PJ_INFO projInfo = proj_info();
std::cerr << "proj searchpath: " << projInfo.searchpath << std::endl;
return 0;
PROJ-7.1.0, PROJ_LIB not set:
proj searchpath: /home/oreilly/.local/share/proj:/usr/local/share/proj
PROJ-7.1.0, PROJ_LIB=/tmp/mystuff:
proj searchpath: /home/oreilly/.local/share/proj:/tmp/mystuff
PROJ-8.1.0, PROJ_LIB not set:
PROJ-8.1.0, PROJ_LIB=/tmp/mystuff:
Are there bugs in how PROJ_LIB is handled? What is the intended effect of PROJ_LIB on searchpath?
Thanks,
Tom
Thomas C. O'Reilly
Monterey Bay Aquarium Research Institute
7700 Sandholdt Road
Moss Landing, California 95039-9644
831-775-1766 (voice)
831-775-1620 (FAX)
oreilly at mbari.org (email)
http://www.mbari.org (World-wide Web)
"The machine does not isolate us from the great mysteries
of nature, but plunges us more deeply into them."
- ANTOINE DE SAINT-EXUPERY
"Wind, Sand, and Stars" (1939)
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20221005/e33c7aa1/attachment.htm>
More information about the PROJ mailing list
